I have purchased a new type of Zigbee radiator valve. different from the ones I already have. I would very much appreciate if it could be added to Zigbee for Domoticz as well.
It is the _TZE200_6rdj8dzm version of TS601
Unfortunatly this looks one more Tuya model which is not yet integrated into the plugin, I would need much more information
(1) could you please provide a link to the Website where you purchase it, so I can see what it is ?
(2) could you please provide the export.json as explained here https://github.com/zigbeefordomoticz/wi ... -device.md
(3) please do enable debug mode Tuya, Pairing from the WebUI, remove all widgets already created and redo the pairing
(4) provided the logs file from that.
Please make sure to be on the 'develop' branch where the integration will be done (if you are not yet there)
I got them from AliExpress. https://a.aliexpress.com/_EyhnSRx
Not a whole lot of info there…
They were cheap and looked just like the Hama ones you helped me with earlier. I took a gamble here…
I’ll provide the logs.
I only have two of theese, if it won’t work I’ll get more of the Hama kind instead.
The loose Zigbee standard and these ”Tuya” devices are really confusing
The Setpoint widget is updated when the temp is changed on the TRV, but the value is multiplied by 10, so 19 degrees becomes 190 degrees.
I’m not able to set the value from the widget.
The temp sensor shows no value at all.
The ”ThermoMode” switch is a selector switch with the values ”off” ”auto” and ”heat”. Changing it does nothing and it stays in the ”off” position.
pipiche wrote: ↑Monday 13 March 2023 19:58
Are you able to change the Mode from the device ?
Yes but the device only has two modes according to the instruction sheet, "manual" and "programming" mode, whatever that is. Heating mode is just an indicator.
My Hama TRVs only had an On/Off widget in Domoticz.
the restart and check if the Setpoint and Temp are correctly reported now ?
Yes! It seems to be reporting back correctly now, the temperature is working as well.
Ok good so give me a day or two and I'll be back with Setpoint from Domoticz and I'll do the changes for the Mode and the Heating indicator
restart, check that you still have Temperature and Setpoint correctly received by Domoticz. Then check if you can set Setpoint from Domoticz
In case of issue, please provides the log file.
How do you think the Heating status should be reported ? By that I mean which type of Widget do you think should be used ?
If you are able to retrieve the latest 'develop' branch, I suggest that you remove all existing widget get the device removed also from plugin and then redo the full pairing.
Hi, I have recently installed seven TRV 602 zigbee radiator valves. I have them imported into domoticz through the tinytuya plugin, which uses the Tuya cloud wit a developer account. Since I dont want to have my heating depending on some cloud service, I have been trying to get them straight into domoticz for a few weeks now. My first idea was to get them into a sonoff bridge pro and link that to domoticz. However a I could not get that to work even with a simple sonoff temp/hum sensor. Now I have a USB adaptor installed and ZIgbee2domoticz works. The TRV was not recognized though, and I could not make de development branch work. However I have exported the API response from the TUYA cloud, and maybe this will help getting the TRV 601 into Zigbeefor domoticz as well. I really hope you can help out with this. The radiator valves work fine and have a configurable display.
hyeronimo wrote: ↑Thursday 16 March 2023 21:26
TRV_data.xlsx
There is plenty models of TRV 602 from Tuya, so in order to get them configured properly into the plugin , you need to pair it to the plugin and to provide the Model name and the export.json associated .
Hi Pipiche, thanks for your quick answer
Ok, here is the object info and the json export from raw devices. The Temp/hum is also in there. Is the model name you are looking for in this info or should I look for it in the Tuya portal?
