Zigate repair problem aqara bulb
RezaRose
Post by RezaRose »
I had problems with my Zigate USB, there was a error, witch i do not remember. But after a long search i find somewhere that there was a possibility that the ?PDC? was corrupted. I tried to fix it and then i broke my pi OS... :roll: A good time to start fresh.
So i have a new pi OS installed and updated, new firmware on the zigate (switched to OPDM) new fresh install of domoticz stable, with on this moment only the philips hue bridge plugin and the Zigbee for Domoticz plugin. Paired a plug to test, it works!
But now i want to re-pair my aqara lightbulbs and i get a error.
2023-03-13 14:29:50.425 Status: Zigate: Accepting new Hardware: Enable (On)
2023-03-13 14:30:06.490 Status: Zigate: [None] NEW OBJECT: 406c None
2023-03-13 14:30:06.734 Status: Zigate: [-] NEW OBJECT: 406c Active Endpoint Response Ep: 01 LQI: 186
2023-03-13 14:30:09.081 Status: Zigate: [0] NEW OBJECT: 406c Model Name: lumi.light.aqcn02
2023-03-13 14:30:09.087 Status: Zigate: [None] NEW OBJECT: 406c Request Node Descriptor
2023-03-13 14:30:11.116 Error: Zigate: Decode8000 - PacketType: 00e0 TypeSqn: 01 sqn_app: 00 sqn_aps: 65 Status: [06]
There is a widget, but the light does not respond on it. The only error i get is the one with pairing.
I repaired the bulb a couple times, tried another aqara bulb, same error.. I googled the error but i can not find anything on it.
I have a aqara doorsensor, it is working fine. Just like the Plug
Things i tried
- Removed widget and re- paired the bulb
- used other bulb
- restart plugin
- stopped plugin, remove zigate for 1 min and the reconnect it again.
Screenshot 2023-03-13 201138.png (57.88 KiB) Viewed 648 times
Raspberry Pi 4 - Raspbian bullseye - Python 3.9 - stable
Dashticz on apache2 - Mqqt - node red
Zigate - USB Tll - Philips hue - Ikea - Innr - Xiaomi - TPlink - Nest -v3
RezaRose
Re: Zigate repair problem aqara bulb
Post by RezaRose »
The first bulb that failed was a E27
Now i tried to pair a E14 bulb. And the log was filled with the same response.... After 2 minutes i tried to repair it again. And now i have a error too. The log is so long i cant scroll back anymore, but is i filter on errors, i get two errors
2023-03-13 20:30:54.226 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:54.227 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:54.227 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:54.228 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:54.331 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:54.331 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:54.332 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:54.332 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:54.333 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:54.333 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:54.334 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:54.335 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:54.437 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:54.438 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:54.439 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:54.439 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:54.440 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:54.440 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:54.441 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:54.441 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:54.544 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:30:54.545 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:54.546 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:54.546 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:54.547 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:54.547 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:54.548 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:54.548 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:54.651 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:54.652 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:54.652 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:54.653 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:54.653 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:54.654 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:54.654 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:54.655 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:54.758 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:54.758 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:54.759 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:54.759 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:54.760 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:54.760 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:54.761 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:54.762 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:54.865 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:30:54.866 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:54.867 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:54.867 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:54.868 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:54.868 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:54.869 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:54.869 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:54.968 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:54.971 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:54.972 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:54.972 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:54.973 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:54.973 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:54.974 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:54.974 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:55.077 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:30:55.078 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:55.078 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:55.078 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:55.079 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:55.079 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:55.080 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:55.080 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:55.182 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:30:55.183 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:55.183 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:55.184 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:55.184 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:55.185 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:55.185 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:55.186 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:55.290 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:55.290 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:55.291 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:55.291 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:55.292 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:55.292 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:55.293 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:55.293 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:55.396 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:30:55.397 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:55.398 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:55.398 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:55.399 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:55.399 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:55.400 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:55.400 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:55.503 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:55.504 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:55.504 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:55.505 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:55.505 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:55.506 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:55.506 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:55.507 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:59.239 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:59.240 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:59.240 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:59.241 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:59.344 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:30:59.345 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:59.345 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:59.346 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:59.346 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:59.347 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:59.348 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:59.348 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:59.451 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:30:59.451 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:59.452 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:59.452 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:59.453 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:59.453 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:59.454 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:59.454 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:59.558 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:59.558 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:59.559 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:59.559 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:59.560 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:59.560 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:59.561 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:59.562 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:59.665 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:59.666 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:59.666 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:59.667 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:59.668 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:59.668 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:59.669 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:59.669 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:59.770 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:30:59.770 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:59.771 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:59.771 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:59.772 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:59.772 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:59.773 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:59.773 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:59.878 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:30:59.878 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:59.879 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:59.879 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:59.880 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:59.880 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:59.881 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:59.882 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:30:59.984 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:30:59.985 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:30:59.986 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:30:59.986 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:30:59.987 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:30:59.987 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:30:59.988 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:30:59.988 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:00.091 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:31:00.092 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:31:00.093 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:31:00.093 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:31:00.094 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:00.094 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:00.095 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:00.095 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:00.198 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:31:00.199 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:31:00.199 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:31:00.200 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:31:00.200 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:00.201 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:00.201 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:00.202 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:00.305 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:31:00.305 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:31:00.306 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:31:00.306 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:31:00.307 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:00.308 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:00.308 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:00.309 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:00.411 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:31:00.412 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:31:00.413 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:31:00.413 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:31:00.414 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:00.414 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:00.415 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:00.415 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:00.518 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:31:00.519 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:31:00.519 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:31:00.520 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:31:00.520 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:00.521 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:00.522 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:00.522 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:04.257 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:04.257 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:04.258 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:04.258 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:04.365 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:31:04.365 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:31:04.366 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:31:04.367 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:31:04.367 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:04.368 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:04.369 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:04.369 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:04.471 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:31:04.472 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:31:04.472 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:31:04.473 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:31:04.473 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:04.474 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:04.474 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:04.475 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:04.576 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 102
2023-03-13 20:31:04.577 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:31:04.577 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:31:04.578 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:31:04.578 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:04.579 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:04.579 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:04.580 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:04.684 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:31:04.685 Status: Zigate: [-] NEW OBJECT: c9b1 ProfileID a1e0
2023-03-13 20:31:04.685 Status: Zigate: [-] NEW OBJECT: c9b1 ZDeviceID 0061
2023-03-13 20:31:04.686 Status: Zigate: [-] NEW OBJECT: c9b1 Application Version 0000
2023-03-13 20:31:04.686 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster IN Count: 00
2023-03-13 20:31:04.687 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster OUT Count: 01
2023-03-13 20:31:04.688 Status: Zigate: [-] NEW OBJECT: c9b1 Cluster Out 1: 0021
2023-03-13 20:31:04.688 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:04.791 Status: Zigate: [-] NEW OBJECT: c9b1 Simple Descriptor Response EP: 0xf2 LQI: 99
2023-03-13 20:31:51.660 Status: Zigate: [-] NEW OBJECT: c9b1 Request Simple Descriptor for Ep: f2
2023-03-13 20:31:55.413 Status: Zigate: (c9b1/588e81fffee3c1ea) sent a Leave indication and will be outside of the network. LQI: 132
2023-03-13 20:31:55.414 Status: Zigate: (c9b1/588e81fffee3c1ea) cleanup key plugin data informations
2023-03-13 20:31:58.005 Status: Zigate: reconnectNWkDevice - Update Status from inDB to 'inDB' for NetworkID : fcca
2023-03-13 20:31:58.012 Status: Zigate: NetworkID: fcca is replacing c9b1 for object: 588e81fffee3c1ea
2023-03-13 20:31:58.024 Status: Zigate: Device Annoucement: NwkId: fcca Ieee: 588e81fffee3c1ea MacCap: 8e
2023-03-13 20:32:00.550 Error: Zigate: Decode8000 - PacketType: 00e0 TypeSqn: 01 sqn_app: 00 sqn_aps: ba Status: [06]
2023-03-13 20:29:54.920 Error: Zigate: Decode8000 - PacketType: 00e0 TypeSqn: 01 sqn_app: 00 sqn_aps: 7a Status: [06]
RezaRose
Post by RezaRose »
Ok I tried Provisioning-> 'Prepairing device for full reset', deleted the widget. Reset the bulb, and then repaired it.
It did not create widget anymore, but i can put it on and off with the zigate's tools-> commands now. Wich i could not do yesterday
Recreated a widget with Provisioning - Recreate widget.
But nothing happends if i try to command it with Domoticz widget
here is the raw devices data
[{"Status":"","RIA":"10","ZDeviceName":"Zigbee Coordinator","GroupMemberShip":{"01":{"0000":{"Status":"OK"}}},"Ep":{"15":{"1000":{},"0000":{},"0003":{},"0204":{},"0b03":{},"0300":{},"0004":{},"0008":{},"0006":{},"0005":{},"0101":{},"0702":{},"0500":{},"0019":{},"0201":{},"0401":{},"0400":{},"0406":{},"0403":{},"0405":{},"0402":{},"0001":{},"0b05":{}},"01":{"1000":{},"0000":{},"0003":{},"0019":{},"000f":{},"0501":{},"0b03":{},"0300":{},"0004":{},"0008":{},"0006":{},"0005":{},"0702":{},"0500":{},"0201":{},"0401":{},"0400":{},"0406":{},"0403":{},"0405":{},"0402":{},"0204":{},"0001":{},"0b05":{}},"0b":{"0000":{},"0019":{}},"0a":{"1000":{},"0000":{},"0003":{},"0204":{},"0b03":{},"0300":{},"0004":{},"0008":{},"0006":{},"0005":{},"0101":{},"0702":{},"0500":{},"0019":{},"0201":{},"0401":{},"0400":{},"0406":{},"0403":{},"0405":{},"0402":{},"0001":{},"0b05":{}},"6e":{"1000":{},"0000":{},"0003":{},"0204":{},"0b03":{},"0300":{},"0004":{},"0008":{},"0006":{},"0005":{},"0101":{},"0702":{},"0500":{},"0019":{},"0201":{},"0401":{},"0400":{},"0406":{},"0403":{},"0405":{},"0402":{},"0001":{},"0b05":{}},"08":{"0001":{}},"03":{"0000":{},"0019":{}}},"PowerSource":"Main","IEEE":"00158d00021e2bb6","Version":"3","LogicalType":"Coordinator","Health":"","ConsistencyCheck":"","Model":"ZiGate Classic PDM (OptiPDM)","Last Cmds":[[11,"02","0000","0060","01010000"],[12,"02","0000","0061","01010000"]],"NwkID":"0000"},{"Version":"3","ZDeviceName":"","Status":"inDB","SQN":"65","Ep":{"01":{"0000":{"0004":"_TZ3000_vtscrpmw","0000":"3","0001":"65","0005":"TS0121","0007":"1","fffe":"0","ffe2":"31","ffdf":"ԡ+\u0012"},"0004":{},"0005":{},"0006":{"4001":"0","4002":"0","8001":"1","8002":"2","8003":"00","0000":"00"},"000a":{},"0702":{"0000":115210},"0b04":{"0508":0,"050b":0,"0505":228},"0019":{},"Type":"Plug/Power/Meter/Voltage","ClusterType":{"3":"Plug","4":"Power","5":"Meter","6":"Voltage"}}},"Heartbeat":"1181","RIA":"0","LQI":150,"Battery":{},"Model":"TS0121","ForceAckCommands":[],"MacCapa":"8e","IEEE":"842e14fffe12674d","Type":"Plug/Power/Meter/Voltage","ProfileID":{},"ZDeviceID":{},"App Version":"65","Attributes List":{},"DeviceType":"FFD","HW Version":"","Last Cmds":[[20,"07","f3f6","0100","01010b04000000000305050508050b"],[41,"07","f3f6","0100","01010b04000000000305050508050b"]],"LogicalType":"Router","Manufacturer":"1002","Manufacturer Name":"_TZ3000_vtscrpmw","NbEp":"1","PowerSource":"Main","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":"14/03/2023 21:22:59","iSQN":{"0004":42,"0000":42,"0001":42,"0005":42,"0007":42,"fffe":42},"Attributes":{"0001":"00","ffe2":"00","ffdf":"00","0004":"00","0000":"00","0005":"00","0007":"00","fffe":"00"},"ZigateRequest":{}},"0006":{"TimeStamp":"14/03/2023 19:45:30","iSQN":{"4001":40,"4002":40,"5000":40,"8000":40,"8001":40,"8002":41,"8003":41,"0000":14},"Attributes":{"4001":"00","4002":"00","5000":"86","8000":"86","8001":"00","8002":"00","8003":"00","0000":"00"},"ZigateRequest":{}},"0702":{"TimeStamp":"14/03/2023 21:24:01","iSQN":{"0000":39},"Attributes":{"0000":"00"},"ZigateRequest":{}},"0019":{"TimeStamp":"13/03/2023 12:07:03","iSQN":{"0001":37,"0002":37,"0003":37,"0004":37,"0005":37,"0006":37,"0007":38,"0008":38,"0009":38,"000a":38},"Attributes":{"0001":"86","0002":"86","0003":"86","0004":"86","0005":"86","0006":"86","0007":"86","0008":"86","0009":"86","000a":"86"},"ZigateRequest":{}},"0b04":{"TimeStamp":"14/03/2023 21:21:36","iSQN":{"0505":41,"0508":41,"050b":41},"Attributes":{"0505":"00","0508":"00","050b":"00"},"ZigateRequest":{}}}}},"ReceiveOnIdle":"","Stack Version":"","Stamp":{"time":1678825441.0099,"Time":"2023-03-14 21:24:01","MsgType":"8011","LastSeen":"14/03/2023 21:24:01"},"ZCL Version":"3","Health":"Live","Bind":{"01":{"0019":{"Target":"0000","Stamp":"13/03/2023 12:07:02","Phase":"binded","Status":"00","i_sqn":32},"0006":{"Target":"0000","Stamp":"14/03/2023 09:07:03","Phase":"binded","Status":"00","i_sqn":1491},"0702":{"Target":"0000","Stamp":"14/03/2023 09:07:03","Phase":"binded","Status":"00","i_sqn":1493},"0b04":{"Target":"0000","Stamp":"14/03/2023 09:07:03","Phase":"binded","Status":"00","i_sqn":1495}}},"CertifiedDevice":true,"ReadConfigureReporting":{"Ep":{"01":{"0006":{"0000":{"TimeStamp":"14/03/2023 09:07:03","Status":"00","DataType":"10","MinInterval":"0001","MaxInterval":"012c"}},"0702":{"0000":{"TimeStamp":"14/03/2023 09:07:04","Status":"00","DataType":"25","MinInterval":"001e","MaxInterval":"001e"}},"0b04":{"050b":{"TimeStamp":"14/03/2023 09:07:04","Status":"00","DataType":"00","MinInterval":"0501","MaxInterval":"2900"}}}},"TimeStamp":"14/03/2023 09:07:04"},"Epv2":{"01":{"ClusterIn":{},"ClusterOut":{},"ProfileID":{},"ZDeviceID":{}}},"Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"Max Buffer Size":"52","macapa":"8e","Max Rx":"0052","BindingTable":{"SQN":0,"Status":"Success","TimeStamp":"13/03/2023 12:07:04","BindingTableSize":4,"Devices":[{"842e14fffe12674d":{"sourceEp":"01","Cluster":"0006","targetIEEE":"00158d00021e2bb6","targetNickName":"Zigbee Coordinator","targetEp":"01"}},{"842e14fffe12674d":{"sourceEp":"01","Cluster":"0702","targetIEEE":"00158d00021e2bb6","targetNickName":"Zigbee Coordinator","targetEp":"01"}},{"842e14fffe12674d":{"sourceEp":"01","Cluster":"0b04","targetIEEE":"00158d00021e2bb6","targetNickName":"Zigbee Coordinator","targetEp":"01"}},{"842e14fffe12674d":{"sourceEp":"01","Cluster":"0019","targetIEEE":"00158d00021e2bb6","targetNickName":"Zigbee Coordinator","targetEp":"01"}}]},"bitfield":"4001","Param":{"PowerOnAfterOffOn":2,"IndicatorMode":1,"PowerPollingFreq":300},"descriptor_capability":"00","Max Tx":"0052","ConfigSource":"DeviceConf","_rawNodeDescriptor":"1002005200522c00008e524001","ConfigureReporting":{"Ep":{"01":{"0006":{"TimeStamp":"14/03/2023 09:07:03","iSQN":{"0000":1492},"Attributes":{"0000":"00"},"ZigateRequest":{}},"0702":{"TimeStamp":"14/03/2023 09:07:03","iSQN":{"0000":1494},"Attributes":{"0000":"00"},"ZigateRequest":{}},"0b04":{"TimeStamp":"14/03/2023 09:07:03","iSQN":{"050b":1496},"Attributes":{"050b":"00"},"ZigateRequest":{}}}}},"server_mask":"2c00","WriteAttributes":{"Ep":{"01":{"0000":{"TimeStamp":"13/03/2023 12:06:51","iSQN":{"ffde":44},"Attributes":{"ffde":"00"},"ZigateRequest":{"ffde":{"Status":"fullfilled","DataType":"20","EPin":"01","EPout":"01","manuf_id":"0000","manuf_spec":"00","data":"13","ackIsDisabled":false}}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0005":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"000a":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0702":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0b04":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"CheckParam":false,"ConsistencyCheck":"ok","RollingLQI":[150,150,150,147,147,147,147,147,147,150,150],"SQN_000a":"63","NwkID":"f3f6"},{"Version":"3","ZDeviceName":"","Status":"inDB","SQN":"22","Ep":{"01":{"0000":{"0005":"lumi.sensor_magnet.aq2","0001":"3","ff01":"01219f0b0328160421a8130521a100062401000000000a21f6f3641000","0004":"LUMI"},"0006":{"0000":"00"},"0003":{},"ffff":{},"Type":"Door","ClusterType":{"26":"Door"},"0001":{"0000":2975}}},"Heartbeat":"18190","RIA":"0","LQI":147,"Battery":56,"Model":"lumi.sensor_magnet.aq2","ForceAckCommands":[],"MacCapa":"80","IEEE":"00158d0004798669","Type":"Door","ProfileID":{},"ZDeviceID":{},"App Version":"3","Attributes List":{},"DeviceType":"RFD","HW Version":"","Last Cmds":[],"LogicalType":"End Device","Manufacturer":"1037","Manufacturer Name":"LUMI","NbEp":"","PowerSource":"Battery","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":"14/03/2023 20:18:48","iSQN":{"0004":310,"0005":310,"ff01":310,"ff02":311},"Attributes":{"0001":"00","0004":"00","0005":"00","ff01":"00","ff02":"86"},"ZigateRequest":{}},"0006":{"TimeStamp":"14/03/2023 13:35:19","iSQN":{},"Attributes":{"0000":"00"},"ZigateRequest":{}}}}},"ReceiveOnIdle":"","Stack Version":"","Stamp":{"time":1678821528.8132644,"Time":"2023-03-14 20:18:48","MsgType":"8102","LastSeen":"14/03/2023 20:18:48"},"ZCL Version":"","Health":"","CertifiedDevice":true,"LUMI":{"DeviceTemperature":56.4,"RSSI dB":-95,"LQI":"0100","BatteryVoltage":2975},"Capability":["Reduced-Function Device","Standard security","NwkAddr should be allocated"],"Max Buffer Size":"7f","macapa":"80","Max Rx":"0064","BindingTable":[{"Devices":[],"SQN":0,"Status":"","TimeStamp":"13/03/2023 19:52:14","Time":"13/03/2023 19:52:14"}],"bitfield":"4002","descriptor_capability":"00","Max Tx":"0064","ConfigSource":"DeviceConf","_rawNodeDescriptor":"103700640064000000807f4002","server_mask":"0000","BatteryUpdateTime":"14/03/2023 20:18:48","WriteAttributes":{"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0003":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"ffff":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"ConsistencyCheck":"ok","NwkID":"a159"},{"Version":"3","ZDeviceName":"","Status":"inDB","SQN":"0b","Ep":{"0b":{"1000":{},"0000":{},"0003":{},"0004":{},"0005":{},"0006":{},"0008":{},"0300":{},"0019":{},"Type":"ColorControlWW","ClusterType":{"27":"ColorControlWW"}},"f2":{"0021":{},"Type":""},"01":{"0000":{"0001":"23","ff01":"03285905211b000727000000000000000008211701092100020a2100006420016520ff66219900","0005":"lumi.light.aqcn02","0006":"11-22-2018"},"0006":{"0000":"","f000":117440615},"0008":{"0000":"ff","f000":"00844300"},"ClusterType":{"28":"ColorControlWW"}}},"Heartbeat":"64","RIA":"0","LQI":108,"Battery":{},"Model":"lumi.light.aqcn02","ForceAckCommands":[],"MacCapa":"8e","IEEE":"00158d000410f364","Type":"ColorControlWW","ProfileID":{},"ZDeviceID":{},"App Version":"23","Attributes List":{},"DeviceType":"FFD","HW Version":"","Last Cmds":[[34,"07","8443","0100","010b000800000000010000"],[35,"07","8443","0100","0101000800000000010000"],[36,"07","8443","0100","010b000600000000010000"],[37,"07","8443","0100","0101000600000000010000"],[38,"07","8443","0100","010b000800000000010000"],[39,"07","8443","0100","0101000800000000010000"],[43,"07","8443","0100","010b000600000000010000"],[44,"07","8443","0100","0101000600000000010000"],[45,"07","8443","0100","010b000800000000010000"],[46,"07","8443","0100","0101000800000000010000"]],"LogicalType":"Router","Manufacturer":"115f","Manufacturer Name":"","NbEp":"1","PowerSource":"Main","ReceiveOnIdle":"","Stack Version":"","Stamp":{"time":1678825343.4114444,"Time":"2023-03-14 21:22:23","MsgType":"8102","LastSeen":"14/03/2023 21:22:23"},"ZCL Version":"","Health":"Live","CertifiedDevice":true,"Epv2":{"01":{"ClusterIn":{},"ClusterOut":{},"ProfileID":{},"ZDeviceID":{}}},"LUMI":{"DeviceTemperature":227.9,"RSSI dB":-229},"Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"Max Buffer Size":"7f","macapa":"8e","Max Rx":"0064","bitfield":"4001","Param":{"PowerOnAfterOffOn":255,"OnOffPollingFreq":300,"fadingOff":0,"moveToColourTemp":0,"moveToLevel":0},"descriptor_capability":"00","Max Tx":"0064","ConfigSource":"DeviceConf","_rawNodeDescriptor":"115f006400640000008e7f4001","server_mask":"0000","CheckParam":false,"ConsistencyCheck":"","RollingLQI":[114,114,147,114,111,111,114,111,111,111,108],"Bind":{"0b":{"0019":{"Target":"0000","Stamp":"14/03/2023 21:16:40","Phase":"binded","Status":"00","i_sqn":17}}},"BindingTable":{"SQN":0,"Status":"Success","TimeStamp":"14/03/2023 21:16:40","BindingTableSize":1,"Devices":[{"00158d000410f364":{"sourceEp":"0b","Cluster":"0019","targetIEEE":"00158d00021e2bb6","targetNickName":"Zigbee Coordinator","targetEp":"01"}}]},"ZDPSQN":"01","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":"14/03/2023 21:22:23","iSQN":{},"Attributes":{"0006":"00","ff01":"00","0005":"00"},"ZigateRequest":{}},"0008":{"TimeStamp":"14/03/2023 21:24:41","iSQN":{"0000":46},"Attributes":{"f000":"00"},"ZigateRequest":{}},"0006":{"TimeStamp":"14/03/2023 21:24:41","iSQN":{"0000":44},"Attributes":{"f000":"00"},"ZigateRequest":{}}},"0b":{"0006":{"TimeStamp":"14/03/2023 21:24:41","iSQN":{"0000":43},"Attributes":{},"ZigateRequest":{}},"0008":{"TimeStamp":"14/03/2023 21:24:41","iSQN":{"0000":45},"Attributes":{},"ZigateRequest":{}}}}},"SWBUILD_1":"11-22-2018","WriteAttributes":{"Ep":{"0b":{"1000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0003":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0005":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0008":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0300":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}},"f2":{"0021":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}},"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0008":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"NwkID":"8443"}]
pipiche
Post by pipiche »
The error you are reporting are a Zigate issue. in some forum I read that it could be related to the number of group the Zigate belongs too.
RezaRose
Post by RezaRose »
Thank you for responding.
Yes i have read that too. But because it is a new firmware and database. i have only one group, it is the 0000 group. and only 2 devices connected.
Sadly i can not find anything useful on the internet.
Should i go back to the old firmware to test if it is a bug?
RezaRose
Post by RezaRose »
Today i updated the Zigate plugin to 6.3.012 and one of the 2 bulbs i tested is working now. The other one still giving the error.
They are excacly the same model. I dont know what to do, i think i'm going to reinstall the firmware.
RezaRose
Post by RezaRose »
I reinstalled the firmware and plugin today, back to legacy 0323.
At first i could pair nothing. I set the devices in pair mode, zigate in accepting hardware, but zigate finds nothing...not the switches, not the lightbulb, not any device.
Rebooted a couple of times. Now i can pair devices. But still get the error. I begin to wonder if the zigate is just broken.
3-04-06 16:49:15.412 Status: Zigbee: Accepting new Hardware: Enable (On)
2023-04-06 16:49:32.635 Status: Zigbee: [None] NEW OBJECT: a3e2 None
2023-04-06 16:49:32.858 Status: Zigbee: [-] NEW OBJECT: a3e2 Active Endpoint Response Ep: 01 LQI: 192
2023-04-06 16:49:33.094 Status: Zigbee: [0] NEW OBJECT: a3e2 Model Name: lumi.light.aqcn02
2023-04-06 16:49:33.100 Status: Zigbee: [None] NEW OBJECT: a3e2 Request Node Descriptor
2023-04-06 16:49:34.997 Error: Zigbee: Decode8000 - PacketType: 00e0 TypeSqn: 01 sqn_app: 00 sqn_aps: e9 Status: [06]
On the internet i can't find antything usefull except that status 06 means there is some unknown error.
pipiche
Post by pipiche »
when you switch back the firmware back to 0223 did you do the Erase EEPROM (and then Initialize it with the plugin ) ?
That would be a must when changing from OPTIPDM to Legacy and also when downgrading.
Consequently, you'll have to repair all devices
RezaRose
Post by RezaRose »
pipiche wrote: Thursday 06 April 2023 16:59 when you switch back the firmware back to 0223 did you do the Erase EEPROM (and then Initialize it with the plugin ) ?
Yes i have erased eeprom, at the beginning of this topic, i began with new install Raspberry bullseye, Domoticz, new firmware with erase of eerprom and initialize plugin ( I wanted to start over, but i regret that very much now. )
