Does anyone used already the Sonoff ZBMINI L2? This is the successor of the Sonoff ZBMINI L... Advantage: it is smaller!
How can I be sure this is supported? On the https://zigbee.blakadder.com/Sonoff_ZBMINIL2.html, it is not yet confirmed.
Thanks for feedback.
F
Sonoff ZBMINI L2
Re: Sonoff ZBMINI L2
I don't see any reason why it shouldn't work.
In fact you many objects ( which are following Zigbee 3.0 standard) which run out of the box.
We are most of the time suffering from Tuya devices and Aqara/Xiaomi devices which used Private and undocumented clusters.
So the only thing that I can see is that the plugin will complain that the device is not optimized but won't prevent working.
Wiki is available here.
Zigbee for Domoticz FAQ
- Target OS: -
Supported ? on wich one application ?
Like have said @pipiche If it's not, it can be, and don't take care at the site blakadder, information are never in date, they need an user update the page, and as lot of user have other thing to do, this site is never precise.
Domoticz - ZigbeeForDomoticz (this is the right forum, right)?
Pipiche confirmed it should work... So I ordered some of them and will see.
Thanks all for the feedback!
- Target OS: -
Yes, but all application use the same ^^.this is the right forum, right
And yes, even not supported, pipiche can add them fastly, just ask him if needed.
Just to let you know that it works perfectly!
Installed the device, auto-discovered and visible in Domoticz!
Thanks again.
Filip
Thanks again.
Filip
thanks for the feedbacks.
