[SOLVED] Domoticz/.getAllVariables() ?
Grunnpi
Post by Grunnpi »
Hi there,
I'm trying to build a block content based on a water meter device, and two variables content.
I was planning to perform such things in "custom/.js" with something like
function afterGetDevices(){
	var var1 = Domoticz/.getAllDevices()['vVar1'];
	var var2 = Domoticz/.getAllDevices()['vVar2'];
	var waterMeter = Domoticz/.getAllDevices()['123'];
	Dashticz/.setBlock('target_block', {
		title: 'Water Left ' + var1/.value + var2/.value - waterMeter/.usage
But no "getAllVariables()" as far as I understand.
Any idea or tips to share please ?
Lokonli
Re: Domoticz/.getAllVariables() ?
Post by Lokonli »
You can get Domoticz variable values via Domoticz.getAllDevices()['v123'];
So, put 'v' in front of the variable index.
Grunnpi
Post by Grunnpi »
Oh great !
I did try but then, I tried var1/.value but didn’t return anything.
Is there something to do regarding variable type ? (String, int, …)
Lokonli
Post by Lokonli »
It is case sensitive. Try:
var1.Value
During debugging you could add:
console.log(var1);
then in Devtools (Press F12) console tab you see the debug messages.
Grunnpi
Re: [SOLVED] Domoticz/.getAllVariables() ?
Post by Grunnpi »
Thanks a lot, exactly what I was looking for !
