[closed] syntax to append data to textfile
BartSr
Domoticz version: V2024.7
Post by BartSr »
I am struggeling to get data append to existing textfile
 file = io.open("/home/pi/gas.txt", "w+")
   	file:write("gasstand"..gasstand.."\n")
        file:close() --closes the open file
I borrowed this code partly from a script written by Waaren. It was understood thet the w+ should open the file in append mode.
But every time there is only the new data in the file gas.txt
Where is my error? And where can I find info re create a file if not already exist? To my knowledge quit native but the syntax.....
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Toulon7559
Domoticz version: <2025
Re: syntax to append data to textfile
Post by Toulon7559 »
See the first list under this weblink:
https://www.tutorialspoint.com/python/p ... les_io.htm#
BartSr
Post by BartSr »
Toulon7559, Thanks a lot. You helped me out!
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
