Unauthorized 401 - homebridge
dvdbosch
Post by dvdbosch »
After the most recent 2023 update I'm facing difficulties on authorization between homebride/edomoticz and domoticz.
The following error is shared:
[3-3-2023 19:40:27] Homebridge v1.6.0 (HAP v0.11.0) (Homebridge 602A) is running on port 51402.
[3-3-2023 19:40:27] [Domoticz] There was a problem connecting to Domoticz. (HTTP Status code 401)
<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>
[3-3-2023 19:40:27] [Domoticz] There was an error while getting the MQTT Hardware Device from Domoticz.
Please verify that you have added the MQTT Hardware Device and that the hardware device is enabled.
Any suggestions?
Using the following config in Domoticz
And the following Homebridge config:
            "name": "Domoticz",
            "server": "username:[email protected]",
            "username": "admin",
            "password": "domoticz",
            "port": "8082",
            "roomid": 1,
            "mqtt": true,
            "ssl": false,
            "dimFix": 0,
            "legacyBlinds": 0,
            "platform": "eDomoticz"
Domoticz version
About Domoticz
Version: 2023.1
Build Hash: f9b9ac774
Compile Date: 2023-02-14 15:06:40
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Oct 31 2022, 14:04:00) [GCC 8.3.0]
Active User:
Uptime: 1 Hours, 14 Minutes, 45 Seconds
Thanks for the help! My wife is getting angry by the minute :-)
solarboy
Domoticz version: 2024.6
Re: Unauthorized 401 - homebridge
Post by solarboy »
It works for me with the new update so there is hope. You might want to look at your edomoticz config and check the login details and also your "trusted networks" in Domoticz>Settings>Security.
It might sound stupid but I presume you have restarted Domoticz. I had the same error with a python script which resolved after a restart (or 2).
dvdbosch
Post by dvdbosch »
Thanks for the suggestions. Will give it a try.
Filnet
Domoticz version: 2025.2 ß
Post by Filnet »
I have same problem. Have you solved it?
dvdbosch
Post by dvdbosch »
Nope, not yet. Suggestions are welcome!
georgesorwell
Post by georgesorwell »
I had the same problem.
The solution is indeed to fill in the trusted network field in Domoticz (security tab)
Georges
dvdbosch
Post by dvdbosch »
georgesorwell wrote: Wednesday 22 March 2023 17:34 Hi,
Georges
Can you post your security settings and homebridge config file? Still not working when setting the trusted network.
georgesorwell
Georges
dvdbosch
Post by dvdbosch »
Thanks! Will give it a try tomorrow.
daniellejorge
Post by daniellejorge »
Please help guys!! I am having the same issue!!! I just added a new router (now i have the isp router and mine with a new ip address (wifi) so, showing 3 wifi names (not sure thats the problem!!)
I updated my domoticz, etc to run in the new ip address but don't remember if i did setup a static ip or something like that!! Thru the app of domoticz it's working my blinds and lights, but not thru the homebridge (voice commands) I am getting error [Domoticz] There was a problem connecting to Domoticz. (HTTP Status code 401). TRied to setup the trusted networks but getting error "Invalid location settings".
Anyone can help????
dvdbosch
Post by dvdbosch »
Well! Completely forgotten to post the solution. After ive changed the homebridge/edomoticz setting setting to 'user:pass@ipadress it worked again.
Stumbled into this because a recent update removed this one.
