Before I post an issue in github, just want to make sure it's not something I have/haven't done.
The GP-WOU019BBDWG smarthings plug was working fine with the ZigBeeforDomoticZ plugin until I updated the plugin a few weeks ago.
Apart from ZigBeeforDomoticZ telling me its not optimized it seems to be working fine.
I have tried removing it and re adding it, but still the same.
I am now currently on the config release 6 3 011 branch as I had another device which has its fix on that branch, but the issue with the smarthings plug happened before I switched to that branch.
is there anything I should try before posting an issue in github.
Samsung smartthings plug, Not Optimized after update
Re: Samsung smartthings plug, Not Optimized after update
Please as a minimum describe what your problem is ?
If the issue is just 'Not optimized' the WebUI give you insight on what to do. Simply click on the link on the WebUI dashboard ( More information in the wiki ), which will bring you here https://zigbeefordomoticz.github.io/wik ... evice.html and you'll know what to do
Wiki is available here.
Zigbee for Domoticz FAQ
I don't really have a problem... everything seems to be working fine.
The issue is, as you suggest, it is just 'Not optimized' which is why I am hesitant at creating a github issue.
I have had a look at its json info (attached here), but nothing stands out to me.
If you think its worth creating an issue so it will give me a nice green tick in the device list I'll go ahead and do one.
- export.json.txt
- (9.69 KiB) Downloaded 29 times
I should be releasing 6.3.011 tomorrow.
I have update the "config release 6 3 011 branch ", you can simply do a git pull today to check that things are good, and then as soon as the release is out , you'll simply have to switch to stable6
thanks, back onto stable6 and eveything is good.
