Migating from beta to stable
glory50
Domoticz version: 2022.1
Post by glory50 »
I've googled and searched this forum and didn't found any positive replies.
Is it possible to remigrate drom beta6 to stable6 or not?
If it is, where could I found some tips for it?
Domoticz version: 2025.1
Re: Migating from beta to stable
I think you have to refrase/clarify your question as this makes absolutely no sense.
glory50
Post by glory50 »
Sorry for the "autocorrection". :shock:
Can DomoticZ 2022.2 (build 14810) be migrated back from beta6 to stable6 'cause I know the DB structures are different?
gizmocuz
Post by gizmocuz »
When you update to a new version via the GUI, there is a backup made in the backups folder that you can place back.
Anyway, why would you want to go back a version? If something is not working right, tell us, make a issue
What do you mean with beta6 and stable6? Do you mean ZigbeeforDomoticz plugin versions? You will have to ask that question to the plugin author pipiche and perhaps read the plugin documentation about Domoticz version and plugin version.
glory50
Post by glory50 »
I didn't mean Zigbee. I meant changing (upgrading) DomoticZ beta6 to stable6 with all the current data in the DB.
OK, I found it: https://domoticz.com/wiki/Going_back_to ... us_version.
Thank you!
Good that you found it because I still do not understand stable6 and beta6 in context of Domoticz versions....
https://www.domoticz.com/wiki/Domoticz_ ... _-_Commits
Ps. The only thing you have to do is run ./updaterelease to update or change from beta channel to stable channel in menu setup settings and then check new version in menu setup and update..
