Group Dimmer script
EscApe
Domoticz version: 2020+
Group Dimmer script
Post by EscApe »
This script will let you control a group of dimmers from one virtual dimmer. You can even use different levels per dimmer to deal with brightness differences. Instructions are in the script.
I share this script as is. Feel free to adapt and tinker.
-- Balanced group dimmer by EScApe 2018
-- Version 0.1
-- This virtual dimmer script will control multiple dimmers as a group and dim them with individual relative levels
-- Installation:
--    Create a virtual Dimmer (dummy)
--    Create Domoticz user variable (string) named Cfg_<virtual dimmer name> (eg. 'Cfg_DimmerLivingRoom') and configure it based on the example below
--    Adapt the myname variable in the script to the Domoticz name of this virtual dimmer.
--    Tip: save the script as script_device_<lower_case_dimmer_name>.lua (with underscores instead of spaces) so it will only run if the specified virtual dimmer changes.
-- Configuration:
--    Example configuration (user variable): Lamp1=100,Lamp2=50,Lamp3=75,defaultlevel=50,maxout=1,debug=1
--    In this example Lamp2 will be at half the level compared to Lamp1 (so it Lamp1 is at 50, Lamp2 will be at 25).
--    Not every lightsource has the same maximum brightness and this script helps you balance them to your liking.
--    Make sure there are no extra spaces in the configuration variable and you are using the exact (case sensitive) names for the actual lights (which obviously must be dimmers).
--    Besides the lamps you can also see some (optional) settings in the example:
--    defaultlevel: the level the virtual dimmer is set to when it is turned on (by button or anything else than the slider). Can be usefull if individual lights are also controlled seperately.
--    maxout: with this set to 1 alle lights will be set to maximum brightness (100%) if the virtual dimmer is set to (exactly) 100%. Ignoring the relative brightness settings.
--    debug: if this is set to 1 then the script will generate verbose logging to help you check your configuration and monitor script behaviour.
myname="Dimmer Beneden"
if devicechanged[myname] then
	cfgvar="Cfg_" .. myname
	if not uservariables[cfgvar] then
		print("ERROR! Virtual '" .. myname ..  "' dimmer is missing configuration variable named: '" .. cfgvar .. "'")
	debug=false
	defaultlevel=0
	maxout=false
	lights = {}
	for key, value in string.gmatch(uservariables[cfgvar], "([^=,]+)=(%d+)") do
		if key == 'debug' then
			if value == '1' then
				print('-- starting with debug mode enabled --')
				debug = true
		elseif key == 'defaultlevel' then
			defaultlevel = tonumber(value)
		elseif key == 'maxout' then
				maxout = true
			lights[key] = value
	if debug then
		print("relative light levels:")
		for k, v in pairs(lights) do
			print("> " .. k .. " : " .. v)
		if maxout then print("All lights will be set to their individual maximum when slider is set to 100%") end
	if devicechanged[myname] == 'Off' then
		for lampname, lampmax in pairs(lights) do
			if debug then print("Turn " .. lampname .. " off") end
			commandArray[lampname]='Off'
	elseif devicechanged[myname] == 'On' then
		if defaultlevel > 0 then
			if debug then print("setting to default level: " .. defaultlevel) end
			commandArray[myname] = 'Set Level ' .. defaultlevel
				if debug then print("Turn " .. lampname .. " on") end
				commandArray[lampname]='On'
		dimlevel = tonumber(otherdevices_svalues[myname])/100
		if debug then print("setting relative level to: " .. dimlevel) end
			if maxout and dimlevel == 1 then
				level = 100
				level =  math.floor(dimlevel * lampmax)
			if level > 0 then
				if debug then print("set " .. lampname .. " to " .. level) end
				commandArray[lampname]='Set Level ' .. level
Cyroq
Re: Group Dimmer script
Post by Cyroq »
Thanks for this! I have a few lighting spots that use multiple lightbulbs so I'm very curious about this script. I followed the instructions, but when I toggle the virtual switch to ON the script seem to run twice, turning it off immediately. This is the log:
2019-01-23 16:09:03.134 Status: LUA: -- starting with debug mode enabled --
2019-01-23 16:09:03.134 Status: LUA: relative light levels:
2019-01-23 16:09:03.134 Status: LUA: > Woonkamer2 : 100
2019-01-23 16:09:03.134 Status: LUA: > Woonkamer1 : 100
2019-01-23 16:09:03.134 Status: LUA: All lights will be set to their individual maximum when slider is set to 100%
2019-01-23 16:09:03.134 Status: LUA: setting to default level: 50
2019-01-23 16:09:03.135 Status: EventSystem: Script event triggered: script_device_dimmerwoonkamer
2019-01-23 16:09:03.180 Status: LUA: -- starting with debug mode enabled --
2019-01-23 16:09:03.180 Status: LUA: relative light levels:
2019-01-23 16:09:03.180 Status: LUA: > Woonkamer2 : 100
2019-01-23 16:09:03.180 Status: LUA: > Woonkamer1 : 100
2019-01-23 16:09:03.180 Status: LUA: All lights will be set to their individual maximum when slider is set to 100%
2019-01-23 16:09:03.180 Status: LUA: Turn Woonkamer2 off
2019-01-23 16:09:03.180 Status: LUA: Turn Woonkamer1 off
2019-01-23 16:09:03.180 Status: EventSystem: Script event triggered: script_device_dimmerwoonkamer
Any idea on what I might be doing wrong?
EscApe
Post by EscApe »
I am not at my pc right now, so if still needed I will run some test later. Just a quick check:
You wrote “virtual switch”. It should be a virtual dimmer (slider), but maybe that is what you meant?
Does it behave correctly if you use the slider instead of the toggle button to turn the lights on?
Cyroq
Post by Cyroq »
Sorry, I meant dimmer. The weird thing is I can't use the slider, it's 'stuck'. It behaves like a dimmer that can't get feedback from the device, it seems. So maybe that's why the script is switching it off directly after turning it on?
I just found out that it does turn off the lights when I first turn them on manually. They just won't stay on.
EscApe
Post by EscApe »
That’s strange. The script is not controlling it’s own slider, just the ones in the ‘group’. Please make sure they use different names. Another explanation could be that the dummy dimmer you use as “master” is not created correctly or is being controlled by another script.
Does de slider work when you disable the script?
Cyroq
Post by Cyroq »
Hmm, with the script disabled it doesn't work either. A new dummy dimmer with a random name doesn't slide as well. Are they supposed to slide by default? I only worked with dummy switches before.
EDIT:
I just realized that there's a difference between creating a dimmer dummy from "< Manual Light/Switch" and "Create Virtual Sensors" in the hardware tab. The first one results in Type "Lighting 1" while the other is Type "Light/Switch". However, the Switch Type in Switches > Edit shows "Dimmer" on both dummies, that's why I didn't notice it before.
In other words: I was doing it completely wrong and it's working now! Thanks so much for your work :mrgreen:
sash
Post by sash »
Hi there sorry i am new to domoticz and I am a little confused by the directions
maybe someone can clear it up for me.
for example the from lua script "Dimmer Beneden" is the name of the virtual switch
1- Create a virtual Dimmer (dummy) :
Hardware -> Dummy -> create virtual sensor -> switch -> go to devices change from on/off to dimmer
2 - Create Domoticz user variable (string) named Cfg_<virtual dimmer name> :
based on the name above --- > Cfg_Dimmer_Beneden ( with or with out underscore with or with out case sensitivity ???)
then go to user variables ( found in more options)
Variable name : Cfg_Dimmer_Beneden
Variable type : string
Variable value: Lamp1=100,Lamp2=50,Lamp3=75,defaultlevel=50,maxout=1,debug=1
is Lamp1,Lamp2 and Lamp3 the names of the light switch or device name for the light ??????
3- save the script as -- script_device_<lower_case_dimmer_name>.lua
so if we used the above example name "Dimmer Beneden" then it should become;
script_device_dimmer_beneden.lua
where does one save the script ????? .. /domoticz/scripts/lua ???
as i keep trying but I still can not get it to work for me and I am not sure what i am doing wrong
any help would be welcome thank you
sash
Post by sash »
okay I got it figured out from the example "Dimmer Beneden"
in the end I renamed it all to small case "dimmer_beneden" as the virtual device name.
and renamed accordingly the rest and now it works fine .. I tried with out the underscore in the virtual device name it would not work either .
nitpicker
Domoticz version: 2022.2
Post by nitpicker »
Too bad, not working anymore in version 2023.1
Will check if I can fix it.
EscApe
Post by EscApe »
nitpicker wrote: Saturday 18 February 2023 12:17 Too bad, not working anymore in version 2023.1
Great to see that the script is actually put to good use :)
I am not aware of any changes to Domoticz that would interfere with this script. Could there be another reason for it to stop working?
I am no longer using this script myself, but a much more complicated approach that was not affected by version 2023.1
Hope you can fix it! Please share if you do.
bert
Post by bert »
Here not working anymore either after an update of Domoticz to 2023.1. The script keeps looping and triggering the virtual input dimmer device and setting it to its default value continuously.
I guess 'silent()' is required on line 68 or something; but what is the LUA equivalent for that?
bert
Post by bert »
turned the script into Dzvent and eliminated the need for a uservariable in the process - for anyone also experiencing 'new behavior' from the LUA script.
-- user variable line from LUA version translated into a table and some local variables below it:
-- uitbouw dimmer=100,Ikea kast=100,Eettafel=60,Aanrecht spots dimmer=100,Schemerlamp woonkamer=60,defaultlevel=50,maxout=1
local VIRTUALDIMMER = 'Woonkamer Lichten'
local DIMMERTABLE = { --  [   'Dimmer'   ]  = individual dimmer level
                            ['uitbouw dimmer']  = 100,
                            ['Ikea kast']  = 100,
                            ['Eettafel']  = 60,
                            ['Aanrecht spots dimmer']  = 100,
                            ['Schemerlamp woonkamer']  = 60
local DEFAULTLEVEL = 50
local MAXOUT = true
    active = true,
	logging = {
		level = domoticz.LOG_INFO, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
		marker = VIRTUALDIMMER
		devices = {
			VIRTUALDIMMER   -- define device to trigger this script
	    if (device.state == 'On' and device.lastLevel == device.level ) then -- if the level did not change, the on-button was pressed
              dimlevel = tonumber(DEFAULTLEVEL)/100
           domoticz.log('Setting to default level: '.. DEFAULTLEVEL , domoticz.LOG_INFO)
           for light, dimValue in pairs (DIMMERTABLE) do
       	       	if ( MAXOUT and dimlevel == 1 ) then
				    level = 100
				    level =  math.floor(dimlevel * dimValue)
			    domoticz.log('36: changing ' .. light ..' to relative level: ' .. level, domoticz.LOG_INFO)
                domoticz.devices(light).dimTo(level)
       	        device.dimTo(DEFAULTLEVEL).silent()
        elseif (device.state == 'On' and device.lastLevel ~= device.level ) then -- the dimmer slider was moved; level changed while on
           domoticz.log('Dimmer slider moved from '..device.lastLevel ..' to: ' .. device.level ..' while already on ' , domoticz.LOG_INFO)
           dimlevel = tonumber(device.level)/100
				    level = 100
			    domoticz.log('52: changing ' .. light ..' to ' .. level, domoticz.LOG_INFO)
        elseif (device.state == 'Off') then
            domoticz.log('timer off; lights to off' , domoticz.LOG_INFO)
                domoticz.devices(light).switchOff().checkFirst()
Denny64
Domoticz version: 2023.1
Post by Denny64 »
Great job. It works fine for roller shutter also.
Thanks.
Users browsing this forum: douyou and 1 guest
