Alecto SA33 smoke alarm not detected
pascalsiekman
Post by pascalsiekman »
Hello all,
Im having a RPI Domoticz v3.8153 and RFXCom433E firmware Ext/1020.
In RFXCom Oregon Scientific is enabled.
Also the learn mode is active.
If I push the test button on the Alecto SA33 smoke alarm it will not show up.
What can I do to troubleshoot this.
Greatings Pascal
SweetPants
Re: Alecto SA33 smoke alarm not detected
Post by SweetPants »
Do you mean with "learn mode", "Accept new hardware devices" in the settings menu?
pascalsiekman
Setup:
Hardware/Devices:
Accept new Hardware Devices Allow for 5 Minutes
But also if I use the learn light switch it's not working.
b_weijenberg
Post by b_weijenberg »
Please check with RFXmngr and only Oregon enabled.
If not received contact support rfxcom.com
RFX-433, RFX-433EMC, RFX-868
pascalsiekman
RFXMngr is seeing them.
A
1-3-2018 21:06:05
Packettype = Security1
subtype = SA30 smoke detector
Sequence nbr = 6
id1-3 = 0C9B00 decimal:826112
status = Panic
Signal level = 7 -64dBm
Can I insert them by manual? And not learning mode?
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
I know I'm replying to an old post but I have the same problem.
I have recently replaced a smokedetector and the new one is not detected by domoticz.
RFXmgr is seeing the smokedetector.
This one is not seen by domoticz
Sequence nbr = 1
id1-3 = 157E00 decimal:1408512
status = Panic
This one is seen by domoticz
Sequence nbr = 0
id1-3 = 877A00 decimal:8878592
status = Panic
I haven't upgraded yet to 2023.1
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
