For a fresh installation, i went directly for MQTT Auto Discovery Client Gateway with LAN interface plugin instead of Zigbee2MQTT.
The frontend is working fine on its own,
but get stuck when I call it in Domoticz (message "Unable to find ipaddress server IP address.")
To resolve this starting issue in the 'old' Zifbee2MQTT plugin I precedently had to enable the api_transport device,
but ... there is no such device available with the Auto Discovery flavoured plugin.
Anyone encountered this situation ?
Thanks a lot
My configuration :
frontend:
port: 8080 (of course domoticz is not on this port)
host: 0.0.0.0
No integrated frontend for MQTT Auto Discovery
- gizmocuz
Re: No integrated frontend for MQTT Auto Discovery
Okey that does not make much sense to me... sorry
The log message "Unable to find ipaddress server IP address" is not a message from domoticz, or not the exact message
No frontend?
Zigbee2MQTT and ZWaveJS-UI both have a good frontend
If you have zigbee, you need to install Zigbee2MQTT (I advise to do this via docker compose), enable the home assistant option in zigbee2mqtt when everything is configured correctly
Next in Domoticz, add the MQTT-AD hardware and point to your MQTT broker (which you also installed via docker compose)
No frontend?
- Domoticz version: 2026.3
Here is the instruction to add the frontend of zigbee2mqtt as custom page https://www.domoticz.com/wiki/Zigbee2MQ ... ustom_menu
