Debian 11 fresh install domoticz 2022.2, no luck setting up Zigbee.
tonbor
Post by tonbor »
Debian 11 fresh install domoticz 2022.2, no luck setting up Zigbee. Zigbee2MQTT cannot acces the Sonoff usb dongle with zigbee2mqtt coordinator firmware. So I switched to zigbee for domoticz with same dongle. Installed plugin but no luck, problem with dongle, wrong firmware for plugin?
2023-02-02 08:52:41.221 Error: Zigbee: Error at startup
2023-02-02 08:52:41.233 Error: Zigbee: Coordinator not correctly initialized
Domoticz version: 2024.7
Re: Debian 11 fresh install domoticz 2022.2, no luck setting up Zigbee.
Your Python is working now?
Seeing your other issues perhaps consider te reinstall your system from scratch with Ubuntu.
tonbor
Post by tonbor »
Yes python is working, now getting zigbee in motion, reinstalled domoticz, well kodi is working, jriver is working so reinstall and change to Ubuntu because I can not access my zigbee dongle is not my idea
tonbor
Post by tonbor »
Think got the solution. Zigbee2mqtt is blocking my dongle. sudo systemctl stop zigbee2mqtt did the trick (for now) for the plug in to find the coordinator. So no more zigbee2mqtt, to much trouble. Hope Zigbee to domoticz is more stable, is's working ( for now) :D
