switch turn on off at temperature
anno
Domoticz version: all
Post by anno »
I am working on a dzvents script to turn my "verdelers" on and off when a temperature sensor is above or below a value. Also i want to use thermostat setpoints.
But first first, i did try to turn a switch on but it is not working.. And i did read and read the instructions but i don't find the problem.
return
		-- device triggers
		devices = {
			-- scripts is executed if the device that was updated matches with one of these triggers
			'Woonkamer keuken', -- device name
--			'abc*', -- triggers for all devices which name begins with abc
		-- timer riggers
		timer = {
			-- timer triggers.. if one matches with the current time then the script is executed
			'every minute',
			function(domoticz)
				-- return true or false
    execute = function(domoticz, roomSwitch)
--		if (triggerdItem.active) then -- state == 'On'
--			triggerdItem.switchOff().afterMin(2) -- if it is a switch
        if (device.name == 'Keuken' and device.temperature > 24.8)) then
        devices.switchOff()--.afterMin(2)
        elseif (device.name == 'Keuken' and device.temperature < 24.5)) then
        devices.switchOn()--.afterMin(2)
And how is it possible to let the code only close a group if at least one group remains open?
long time domiticz user, running 8 domoticz installations on vm's nuc i3. And espeay hosting more than 30.
Domoticz version: 2025.1
Re: switch turn on off at temperature
For debugging it is best to use log statements to see if values are as you expect them to be.,
Second please post scripts into code tags, makes it much more readable.
Third, make sure you identify your devices correctly.
You use 'Woonkamer keuken' and 'Keuken'. Keuken will never be triggerd as the triggering device is 'Woonkamer keuken'.
if you want switch or get data from a device that is not used as a trigger then use eg domoticz.devices('Name of Device').switchOn() or domoticz.devices('Name of Device').temperature
Also when mixed triggers (devices and timer) you have to check what is triggered with Roomswitch.IsTimer or Roomswitch.IsDevice.
I do not understand your question regarding Groups. Do you mean Domoticz groups or your heating system groups? And what kind of devices are those in domoticz?
anno
Post by anno »
return
		-- device triggers
		devices = {
		-- timer riggers
		timer = {
			'every minute',
			function(domoticz)
    execute = function(domoticz, roomSwitch.IsTimer)
        if (domoticz.devices('KeukenTM').temperature > 24.8)) then
        domoitcz.devices.switchOff()--.afterMin(2)
        elseif (domoticz.devices('KeukenTM').temperature < 24.5)) then
        domoticz.devices.switchOn()--.afterMin(2)
or
return
		-- device triggers
--		devices = {
--			'Woonkamer keuken', -- device name
		-- timer riggers
		timer = {
			'every minute',
			function(domoticz)
        domoitcz.devices('Woonkamer keuken').switchOff()--.afterMin(2)
        domoticz.devices('Woonkamer keuken').switchOn()--.afterMin(2)
the following part can be deleted from the script.
			function(domoticz)
And please start simple and use the script examples in the documentation https://www.domoticz.com/wiki/DzVents:_ ... r_examples
anno
Post by anno »
waltervl wrote: Wednesday 01 February 2023 10:58 the following part can be deleted from the script.
			function(domoticz)
Of course i already did that, not working, so i did seashed more and more, still nothing is working.....
I know i do something wrong, i don't know what and i can't find it.
return
    on =
        devices = { 'Woonkamer keuken'}
        if (roomSwitch.active and domoticz.devices('KeukenTM').temperature < 24.8) then
        domoticz.devices('AWWoonkamer keuken').switchOn()
        domoticz.notify('This rocks!',
                        'Turns out that it is getting warm here',
                        domoticz.PRIORITY_LOW)
FlyingDomotic
Post by FlyingDomotic »
Try it the opposite way : check temperature change and switch on or off depending on temperature (if I correctly understood the question).
Fredom
Post by Fredom »
anno wrote: Wednesday 01 February 2023 15:31
			function(domoticz)
return
    on =
Hi Anno,
I use the script below. With some adjustments according to your own needs.
return
    on =
        devices =
            'Humidity Garagekamer'    --https://www.techpunt.nl/nl/xiaomi-aqara-temperatuur-en-vochtigheidssensor.html
    logging =
        level  = domoticz.LOG_DEBUG,
        marker = 'Ventilator wasdroger',
    execute   = function(dz, device)
    local fan = dz.devices('Ventilator wasdroger')  --
        if ( device.temperature < 25 or device.humidity < 73 ) and fan.state == 'On' then
            fan.switchOff().silent().repeatAfterSec(1, 2)
        elseif ( device.temperature >= 25 or device.humidity >= 73 )  and  fan.state == 'Off' then
            fan.switchOn()
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2025.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
anno
Post by anno »
Fredom wrote: Wednesday 01 February 2023 20:50
			function(domoticz)
return
    on =
Hi Anno,
return
    on =
        devices =
    logging =
            fan.switchOn()
Yes, thanks, this did work,
return
    on =
        devices =
            'KeukenTM'
    logging =
        marker = 'Woonkamer keuken',
    local verdeler = dz.devices('Woonkamer keuken')  --
        if ( device.temperature > 24.8 ) and verdeler.state == 'On' then
            verdeler.switchOff().silent().repeatAfterSec(1, 2)
        elseif ( device.temperature < 24.5 )  and  verdeler.state == 'Off' then
            verdeler.switchOn()
I need to ask, why does you laundry dryer has a ventilator?
i think i can do a little more/better myself.
-- assumptions:
-- the setpoint is set by a dummy device (not a selector type)
local WP_SWITCH = 'Voorkamer zuid' -- switch device
local TEMP_SETPOINT = 'Thermostaat voorkamer zuid' -- selector dummy device
local TEMP_SENSOR_1 = 'Voorkamer zuidTM'
local BAT_THRESHOLD = 30
local LOGGING = true
return
    on =
        timer =
            'every minute',
    --LOG levell: This is the log level you want for this script. Can be domoticz.LOG_INFO, domoticz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG or domoticz.LOG_ERROR
    --marker: A string that is prefixed before each log message. That way you can easily create a filter in the Domoticz log to see just these messages.
    logging =
        level = LOGGING and domoticz.LOG_DEBUG or domoticz.LOG_ERROR,
        --level = LOGGING and domoticz.LOG_ERROR,
        marker = 'dzVents voorkamer zuid',
    execute = function(dz)
        -- collect all input data
        local verdeler_switch_state = dz.devices(WP_SWITCH).state
        local temp_1 = dz.devices(TEMP_SENSOR_1).temperature
        local setpointValue = dz.devices(TEMP_SETPOINT).setPoint
        -- info only on log level = LOG_DEBUG
        dz.log('WP_SWITCH : ' .. verdeler_switch_state, dz.LOG_DEBUG)
        dz.log('Temp_1 : ' .. temp_1, dz.LOG_DEBUG)
        dz.log('Setpoint_value : ' .. setpointValue, dz.LOG_DEBUG)
        -- now determine what to do
        if (temp_1 >= setpointValue) then
            dz.devices(WP_SWITCH).switchOff().silent()
            dz.log('Target temperature reached, boiler off')
        elseif (temp_1 <= (setpointValue -1)) then
            dz.log('Average temperature more than 1 degree below setpointValue, switchOn during 10 minutes')
            dz.devices(WP_SWITCH).switchOn().silent()
            dz.devices(WP_SWITCH).switchOff().silent().afterMin(2)
        elseif (temp_1 > (setpointValue -1)) then
            dz.log('Average temperature less than 1 degree below setpointValue, switchOn during 5 minutes')
            dz.devices(WP_SWITCH).switchOff().silent().afterMin(1)
Dzvents is really difficult to understand. Did find above code on the forum here, and did some modifications.
Fredom
Post by Fredom »
			function(domoticz)
return
    on =
Hi Anno,
It's not my dryer but in the room where it is.
Glad it works now
Yours sincerely,
Fred
