[HOW TO] Install Domoticz on Odroid C4 (testcase)
Domoticz version: 2026.3
Re: [HOW TO] Install Domoticz on Odroid C4 (testcase)
Didi wrote: Wednesday 11 January 2023 22:47
waltervl wrote: Wednesday 11 January 2023 21:39 And what went wrong when running Domoticz on Ubuntu on Odroid C4?
Lots of things where not working at all or Domoticz did not responded to json calls, http(s) calls, Log rotate did not worked, plugin installations where not going as explained in the Domoticz Wiki and so on.
Because i had a few days of time over, i tried as much possibility's as possible to find a way, most users, would like. Also i tried to keep it documented as much as possible as you can see in my response. I did not noted all, due to the solution was more important. :D
Thanks for documenting this Odroid install, it has been some work I see ;)
It is still strange that on Ubuntu you had so many issues as I run Ubuntu on a X86 and do not experience it. There could be some missing modules and pre installed applications like python but basically the wiki instructions should work on any Ubuntu. But as I do not have an Odroid I cannot check :-)
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
Sjonnie2017 wrote: Wednesday 11 January 2023 17:56 Great write up! Tx!
Method 3 (even easier :) ):
Install Ubuntu 22.04 Minimal from the Hardkernel site/wiki
Install docker
Install official Domoticz docker container.
Run and enjoy
(This is how I am going to use Domoticz when my Odroid M1 arrives ;) )
With some additional how-to's your method might also be a Great write up.
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
igorp
Post by igorp »
There is another simple way to deploy domoticz on any single board computer (also x86 PC).
All you need to do is this:
armbian-config --cmd DOM001
Requirement: Armbian OS, more about this install.
Sources: https://github.com/armbian/configng
