Question about MQTT -problem
BartSr
Domoticz version: V2024.7
Post by BartSr »
My logfile shows:
2023-01-19 19:04:13.175 Error: MQTT: disconnected, restarting (rc=19/Unknown error.)
2023-01-19 19:04:28.253 Error: MQTT: Failed to start, return code: 14/Network is unreachable (Check IP/Port)
2023-01-19 19:05:01.377 Error: MQTT: Failed to start, return code: 14/No route to host (Check IP/Port)
2023-01-19 19:05:34.567 Error: MQTT: Failed to start, return code: 14/No route to host (Check IP/Port)
2023-01-19 19:22:36.973 Error: Otgw: Can not connect to: 192.168.2.108:6638
I don't know exact the meaning nor the meaning of the returncodes.
192.168.2.108:6638 is the IP#/port of the OTGW.
Is there anything I can do to prevent from these errors?
Before I met kind of same errors but could solve by disabling auto back-up of database.
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2025.1
Re: Question about MQTT -problem
If you use mqtt to communicate you should use the IP of the system running the mqtt broker (mostly mosquito) in Domoticz.
So otgw talks to broker, Domoticz talks to same broker. Domoticz is not talking directly with otgw.
So check your settings.
Looking again it seems both MQTT and OTGW (not using MQTT) cannot connect to the systems in your network so it also can be a network issue.
BartSr
Post by BartSr »
Thanks for your suggestion Waltervl.
But the strange thing is :
There are over 40 devices using MQTT.
Wifi is a mesh network with satellites (6 off) well spread over the house. So why only the OTGW cannot connect to the network.
But I realise this should be discussed in other forum.
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Post by BartSr »
I somewhere read in the forum to change the ip# of mosquitto into localhost. So let's see if this makes sense to this case. Meanwhile I changed update of CO2 sensor to 60 sec. Iso 5 sec.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
FlyingDomotic
Post by FlyingDomotic »
As messages "Network is unreachable" and "No route tohost", this can be (roughly):
1) local host not connected to Wifi. Check with ifconfig if interfaces are connected (have IP @). Try to ping some remote nodes. If you have access to Wifi router, try to see if node is connected.
2) destination server is not on the same network and router is not available, or route not properly propagated to local host. Depending on your os, try "route print" or "ip route" to see if you can find some route to destination. Try to ping router to see if it respond.
