I hooked up a Sensair airquality sensor to espeasy.
In espeasy I see correct PPM value
Than I created in Domoticz dummy device airquality
I sent datya from esp easy with command
SendToHTTP,<192.168.2.100>,<8080>,/json.htm?param=udevice&type=command&idx=910&nvalue=401.00
But nothing arrives in Domoticz
Any suggestion?
If I hook the value using MQTT I see in the device list also nothing but if I use instead dummy device "GAS" I see the value as 0.401
-Bart
Problem with PPM indicator
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2025.1
Re: Problem with PPM indicator
If I remember correctly easpeasy has an issue with "?param" statement.
So perhaps try
Also you can try to send integer value instead of decimal so 401 instead if 401.00
So perhaps try
SendToHTTP,<192.168.2.100>,<8080>,/json.htm?type=command¶m=udevice&idx=910&nvalue=401.00Domoticz running on Udoo X86 (on Ubuntu)
- jvdz
- Domoticz version: 4.107
Get rid of the <> in both the IP and port parameters.
- FireWizard
The "Air Quality" sensor accepts only integer values. I see you try to send a number with two digits, 401.00
Try to send only nvalue=401.
BartSr
Yes, removing the < and > did the trick. And yes I left the last digits behind "."
Thanks to both Waltervl as well as jvdz.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
