When the sun is not shining, the inverter is powered down. Which means that the http response will give an error in the domoticz log:
2023-01-17 19:11:03.558 Error: Error opening url: http://xx/js/status.js
2023-01-17 19:11:03.658 Error: dzVents: Error: (3.1.8) Omnik Solar: HTTP/1.1 response: 7 ==>> Couldn't connect to server
Is there a way to prevent that this error message is shown for this particular script? It pollutes my error log every night
local MANUAL_OVERRIDE_SWITCH = 383
local SWITCH_OMVORMER = 382
active = true,
timer = {
'every minute', -- starting from xx:00 triggers every xx minutes (0 > xx < 60)
httpResponses = { "Omnik" }, -- do not change this
devices = {
MANUAL_OVERRIDE_SWITCH,
SWITCH_OMVORMER
logging = {
level = domoticz.LOG_ERROR,
marker = 'Omnik Solar',
data =
last_production =
initial = "0"
execute = function(dz, item)
local script_name = 'Zonnepanelen 🌞: '
-- uitschakelen van script
local manualOverrideSwitch = dz.devices(MANUAL_OVERRIDE_SWITCH)
if (item == manualOverrideSwitch and manualOverrideSwitch.state == 'On') then
telegram.sendText(telegram.getId('rik'), script_name .. 'het script is handmatig uitgeschakeld (disable script switches)')
dz.log(script_name .. 'is handmatig uitgeschakeld (disable script switches)', dz.LOG_DEBUG)
return
local maxResponseSeconds = 720
local OmnikIP = 'xx' -- Your local Omnik inverter IP Address
local production_device = 379 -- IDX of dummy electricity instant and counter device
local total_device = 380 -- IDX of dummy custom sensor (total kwh)
local current_device = 381
local switch_omvormer = dz.devices(SWITCH_OMVORMER)
local alert = dz.devices(378) -- Alert device
local round = dz.utils.round
local function checkWebpageResponse()
local deltaSeconds = dz.time.dDate - dz.data.previousRainSample
if ( maxResponseSeconds > 0 ) and ( deltaSeconds > maxResponseSeconds ) then
dz.notify(scriptVar, 'Omnik Inverter did not respond within ' .. tostring(maxResponseSeconds) .. ' seconds.')
local function getOmnikData()
local urlstring = 'http://' .. OmnikIP .. '/js/status.js'
dz.openURL ({ url = urlstring, callback = "Omnik" })
local function processHTM()
OmnikData = (item.data):gsub('"',''):gsub("'","")
OmnikArray = string.match(OmnikData, 'myDeviceArray%[0%].+,;')
--dz.log('Omnik Array: ' .. OmnikArray,dz.LOG_INFO)
splittedResult = dz.utils.stringSplit(OmnikArray,',')
strOmnikCurrentWatt = splittedResult[2] -- Amount in Watt
strOmnikkWhToday = splittedResult[3] -- Amount in kWh of the day, not used
strOmnikTotalkWh = splittedResult[4] -- Total generated kWh needs to be converted to Wh
OmnikCurrentWatt = tonumber(strOmnikCurrentWatt)
OmnikkWhToday = tonumber(strOmnikkWhToday)/100
OmnikTotalWh = tonumber(strOmnikTotalkWh)*100
--dz.log("Received Data: Current Power: " .. OmnikCurrentWatt ..' W',dz.LOG_INFO)
--dz.log("Received Data: Daily Power: " .. OmnikkWhToday .. ' kWh',dz.LOG_INFO)
--dz.log("Received Data: Total Power: " .. OmnikTotalWh/1000 .. ' kWh',dz.LOG_INFO)
-- update Omnik electricity instant and counter device
dz.devices(production_device).updateElectricity(OmnikCurrentWatt, OmnikTotalWh)
dz.devices(total_device).updateCustomSensor(OmnikTotalWh/1000)
dz.devices(current_device).updateCustomSensor(OmnikCurrentWatt)
-- Main
if item.isTimer then
--checkWebpageResponse()
getOmnikData()
elseif item.isHTTPResponse and item.ok then -- statusCode == 2xx
processHTM(item.data)
switch_omvormer.switchOn().checkFirst()
--dz.log(item.data,dz.LOG_DEBUG)
elseif item.isHTTPResponse then -- Inverter staat uit
--telegram.sendText(telegram.getId('rik'), 'Zonnepanelen komt geen data binnen')
--dz.log('Could not get (good) data from ' .. OmnikIP,dz.LOG_ERROR)
switch_omvormer.switchOff().checkFirst()
elseif item == switch_omvormer then
if switch_omvormer.state == 'Off' then
telegram.sendText(telegram.getId('rik'), script_name .. 'Omvormer schakelt uit, dagproductie:' .. dz.devices(production_device).counterToday .. 'kWh')
elseif switch_omvormer.state == 'On' then
telegram.sendText(telegram.getId('rik'), script_name .. 'Omvormer schakelt in')
if item.isTimer and dz.time.matchesRule('at 22:00') then
local solar_production = dz.devices(production_device).counterToday -- IDX van Productie zonnepanelen in W en totaal kWh
if round(tonumber(solar_production),1) == 0 then
telegram.sendText(telegram.getId('rik'), '🔴 Zonnepanelen lijken niet te werken. Dagproductie: ' .. solar_production .. 'kWh')
alert.updateAlertSensor(dz.ALERTLEVEL_RED, 'Zonnepanelen lijken niet meer te werken')
elseif dz.data.last_production == solar_production then
telegram.sendText(telegram.getId('rik'), '🔴 Zonnepanelen lijken niet te werken. Productie gelijk aan gisteren: ' .. solar_production .. 'kWh')
elseif round(tonumber(solar_production),1) >= 1 then
alert.updateAlertSensor(dz.ALERTLEVEL_GREEN, 'Zonnepanelen werken naar behoren')
-- telegram.sendText(telegram.getId('rik'), 'Zonnepanelen dagproductie:' .. solar_production .. 'kWh')
elseif round(tonumber(solar_production),1) > 0 then
alert.updateAlertSensor(dz.ALERTLEVEL_ORANGE, 'Zonnepanelen lijken slechter te werken')
telegram.sendText(telegram.getId('rik'), '🟡 Zonnepanelen lijken slechter te werken. Dagproductie: ' .. solar_production .. 'kWh')
dz.data.last_production = solar_production
