with the last version of Domticz, I have issue with Zigbee2MQTT.
I would like to try installing an older version (2021.1) to test if the problem is still present.
Could you tell me if there is a place where old versions for Windows are stored?
Old windows versions of Domoticz
- Domoticz version: 2025.1
Re: Old windows versions of Domoticz
There were some python plugin framework changes in Domoticz. Did you also update the python plugin?
With zigbee2mqtt it is currently advised to use the MQTT Autodiscover way. See Domoticz zigbee2mqtt wiki https://www.domoticz.com/wiki/Zigbee2MQTT
Alternatively you can switch to the zigbeeforDomoticz plugin (and do not use zigbee2mqtt)
