Hello. For several days I have a problem with starting the Zigbee2Mqtt service. I noticed that the devices stopped working so I did:
- plugin update
- Domoticz updates
Unfortunately, it didn't help, the service does not want to start. Here's what the journal says.
sty 13 20:26:14 raspberrypi systemd[1]: Main process exited, code=exited, status=1/FAILURE
sty 13 20:26:14 raspberrypi systemd[1]: : Failed with result 'exit-code'.
sty 13 20:26:24 raspberrypi systemd[1]: Service RestartSec=10s expired, scheduling restart.
sty 13 20:26:24 raspberrypi systemd[1]: Scheduled restart job, restart counter is at 109.[/s]
Zigbee2Mqtt cant start
- gizmocuz
Re: Zigbee2Mqtt cant start
you should install zigbee2mqtt via docker compose
