I use this query in a dzVents script of late Waaren ( viewtopic.php?t=30725 )
collects.meters = 'SELECT a.ID Meter, a.Name Name, b.Value Value, b.Usage Usage, b.Date Date '..
' FROM DeviceStatus a , Meter b WHERE AND a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ')'
of course this is OK.
Now I modified to limit to output using:
' FROM DeviceStatus a , Meter b WHERE time(b.Date) = "07:00:01" AND a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ')'
note extended where-clause : time(b.Date) = "07:00:01" AND
But ....
When I create the query in DB Browser for SQLite it's OK. Output as expected.
Same query in Domoticz scripts: no output. Logfile shows ERROR ==>> but no errormessage.
Anyone who knows how to solve?
Thanks.
-Bart
SQL-problem
BartSr
- Domoticz version: V2024.7
SQL-problem
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
willemd
- Domoticz version: 2026.3
Re: SQL-problem
"time" is probably not a function known within dzVents. You will have to use a different method to get the time part of the date field that you selected, depending on what type the date field is. Probably a string?
BartSr
Re: SQL-problem
Date is datetime type. So how to get the timeselectio?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
willemd
Re: SQL-problem
Can you find it here?
https://www.domoticz.com/wiki/DzVents:_ ... nd_methods
Re: SQL-problem
the time statement is in the SQL query so no DzVents option.
I think it has to do with formatting the string and DzVents gets confused? Try to play with quote ' and double quotes "
collects.meters = 'SELECT a.ID Meter, a.Name Name, b.Value Value, b.Usage Usage, b.Date Date FROM DeviceStatus a , Meter b WHERE time(b.Date) = "07:00:01" AND a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ')'
BartSr
Re: SQL-problem
Hi Waltervl,
Quotes, double quotes and square quotes. All the same.
Bart
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
willemd
Re: SQL-problem
and what about a backslash before the double quotes before and after the time ( so \"07:00:01\" ), to indicate to dzVents these should not be treated as double quotes but just past as is.
Re: SQL-problem
Also there is a colon ":" in the string (due to the time 7:00:00 ) that perhaps mixes things up in lua table collects{}???
