I have one Zigbee PIR sensor, several more on order.
The "occupancy" switch works OK now. I have a LUA script to react to this.
But I am trying to set up a LUA script to keep track of the battery level.
So I enabled the "battery low" device, it comes into Domoticz as a simple switch.
When I try to read the status of this switch in LUA, it is not available.
Also, when I click the device list button (top left, in the LUA editor), the device is not there in the list. The "occupancy" device is there.
WHen I try to get the device status via a json command in my browser, status info comes back OK.
Am I missing something?
battery low device not available in LUA
- Domoticz version: 2024.7
Re: battery low device not available in LUA
How is zigbee connected to Domoticz? Zigbee2mqtt? With plugin or MQTT Autodiscover?
- Domoticz version: 2020.2
Problem is no longer a problem for me. I moved to "Zigbee for Domoticz", and discovered that it ha a special display on the dashboard to inform about battery levels of the Zigbee devices. That is sufficient for me.
Hans
And the plugin also sends that data to Domoticz where you can see the battery status in the device overview (menu setup - devices). Also the device widget will go yellow if the battery is low.
