OTGW+NodeMCU: Only 4 devices appear!:-(
For OpenTherm-gateway related questions in Domoticz
McKolders
Post by McKolders »
Hi!
I've been playing with my OTGW device for quite a few hours now, but whatever I try, only four devices appear in Domoticz: GPIOAStatusIsHigh, GPIOBStatusIsHigh, GPIOAPulledToGround & GPIOBPulledToGround.
The hardware: a Nodo-shop OTGW with a NodeMCU for network access. Followed the manual in detail, configured everything as mentioned.
When I run otmonitor (after a hardware reset of the OTGW as Domoticz "kills" otmonitor) it shows data, so my setup seems to work. However when I add the hardware in Domoticz, it only adds four devices, not the 30-something devices I should get. I've read through the topics here, tried them all but so far no luck.
Any help would be greatly appreciated!
Log:
Domoticz log 23-5-2019.txt
(5.75 KiB) Downloaded 144 times
.Michiel.
Vreak77
Domoticz version: 3.8153
Re: OTGW+NodeMCU: Only 4 devices appear!:-(
Post by Vreak77 »
Hi, just a question, as I do encounter a simular kind of issue. Did you allready found a sollution?
Difference on my side is that i do see values in the log, where you get error logs...
