Noob here, please help with connecting to domoticz via web browser
gixfighter
Post by gixfighter »
Hi, noob here and new to odroid, Ubuntu and domoticz.
Hardware: odroid c4
Software Ubuntu 20-04-5 lts 64b
Domoticz v2022-2
Installed domoticz using terminal script and it’s active.
But I cannot acces locally via Firefox running on odroid,
Also not via another computer in the network.
Fixed ip is set at 192 168 2 89
I’m stuck here, have searched and tried a lot but cannot get it to work.
Domoticz version: 2026.3
Re: Noob here, please help with connecting to domoticz via web browser
Should be accessible with http://<IP-of-Domoticz-server>:8080 or https://<IP-of-Domoticz-server>:443
How do you know it is running?
Else check wiki https://www.domoticz.com/wiki/Getting_started or for troubleshooting wiki: https://www.domoticz.com/wiki/Troubleshooting
gixfighter
Thanks for the help.
I know it’s running because when I request the status it tells me it’s active.
I have screenshots but unable to post due to size and not able to scale them down from this device.
Also when I manually start domoticz it starts with no errors. Previously I had ssl errors but managed to resolve that issue.
I will try the troubleshooting link from above post, I didn’t come across that one before but I don’t see a clue in there yet.
I also cannot access through http://127.0.0.1:8080/ on the odroid itself as the ‘getting started’ information says. Which seems like it’s not a network settings issue.
Last edited by gixfighter on Wednesday 28 December 2022 23:11, edited 1 time in total.
gixfighter
Btw, when do you need to fill in user and password for domoticz? I haven’t seen where I can do that yet.
Sorry for being a noob, I’m thinking too difficult maybe.
You are using 2022.2 Stable I presume so no worries about logging in accounts.
What with https url? Also not working? As SSL has something to do with https.
Else I would advise to run ./updaterelease to get Domoticz reinstalled.
What does the log file say when activated to write to OS (see troubleshooting wiki to activate)
gixfighter
This ithe result of manual starting,, which appears to be ok in my opinion.
odroid@odroid:~/domoticz$ sudo ./domoticz
2022-12-29 06:59:23.398 Status: Domoticz V2022.2 (c)2012-2022 GizMoCuz
2022-12-29 06:59:23.398 Status: Build Hash: eea9db734, Date: 2022-11-05 13:05:35
2022-12-29 06:59:23.398 Status: Startup Path: /home/odroid/domoticz/
2022-12-29 06:59:23.506 Status: PluginSystem: Started, Python version '3.9.5', 1 plugin definitions loaded.
2022-12-29 06:59:23.511 Active notification Subsystems: fcm, http (2/13)
2022-12-29 06:59:23.512 Status: WebServer(HTTP) started on address: :: with port 8080
2022-12-29 06:59:23.519 Status: WebServer(SSL) started on address: :: with port 443
2022-12-29 06:59:23.521 Starting shared server on: :::6144
2022-12-29 06:59:23.521 Status: TCPServer: shared server started...
2022-12-29 06:59:23.522 Status: RxQueue: queue worker started...
2022-12-29 06:59:25.523 Status: NotificationSystem: thread started...
2022-12-29 06:59:25.523 Status: EventSystem: reset all events...
2022-12-29 06:59:25.524 Status: EventSystem: reset all device statuses...
2022-12-29 06:59:25.568 Status: Python EventSystem: Initializing event module.
2022-12-29 06:59:25.569 Status: EventSystem: Queue thread started...
2022-12-29 06:59:25.569 Status: EventSystem: Started
The log doesn't seem to work (log file not created), but sure I'm doing this wrong. I've added the last four lines to domoticz.sh:
DAEMON=/home/$USERNAME/domoticz/$NAME
DAEMON_ARGS="-daemon"
#DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log" # or any other OS file
#DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error, debug" # debug disabled for now
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error" # these loglevels will make it to the logfile
#DAEMON_ARGS="$DAEMON_ARGS -debuglevel normal,hardware,received,webserver,eventsystem,python,thread_id"
odroid@odroid:~/domoticz$ sudo systemctl daemon-reload
odroid@odroid:~/domoticz$ sudo service domoticz stop
odroid@odroid:~/domoticz$ sudo service domoticz start
odroid@odroid:~/domoticz$ sudo tail -f /var/log/domoticz.log
tail: cannot open '/var/log/domoticz.log' for reading: No such file or directory
tail: no files remaining
but now when I manually start I get this with some errors:
odroid@odroid:~/domoticz$ ./domoticz
2022-12-29 07:09:01.438 Status: Domoticz V2022.2 (c)2012-2022 GizMoCuz
2022-12-29 07:09:01.438 Status: Build Hash: eea9db734, Date: 2022-11-05 13:05:35
2022-12-29 07:09:01.438 Status: Startup Path: /home/odroid/domoticz/
2022-12-29 07:09:01.574 Status: PluginSystem: Started, Python version '3.9.5', 1 plugin definitions loaded.
2022-12-29 07:09:01.579 Active notification Subsystems: fcm, http (2/13)
2022-12-29 07:09:01.581 Status: WebServer(HTTP) started on address: :: with port 8080
2022-12-29 07:09:01.591 Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied [system:13], trying ::
2022-12-29 07:09:01.594 Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied [system:13], trying 0.0.0.0
2022-12-29 07:09:01.597 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied [system:13]
2022-12-29 07:09:01.597 Error: WebServer(SSL) check privileges for opening ports below 1024
2022-12-29 07:09:01.599 Starting shared server on: :::6144
2022-12-29 07:09:01.600 Status: RxQueue: queue worker started...
2022-12-29 07:09:01.602 Status: TCPServer: shared server started...
2022-12-29 07:09:03.604 Status: NotificationSystem: thread started...
2022-12-29 07:09:03.605 Status: EventSystem: reset all events...
2022-12-29 07:09:03.606 Status: EventSystem: reset all device statuses...
2022-12-29 07:09:03.684 Status: Python EventSystem: Initializing event module.
2022-12-29 07:09:03.685 Status: EventSystem: Started
2022-12-29 07:09:03.685 Status: EventSystem: Queue thread started...
gixfighter
just noticed I'm on Ubuntu 20.04, which is 2yrs old. should I upgrade to 22.04? I'm not sure why I am running 20.04, think I've downloaded the wrong version. 20.04 is at the top of the download link page, which is kinda odd.
Can I do the update without installing all over? or better to download the image to the SD card?
20.04 is fine
It seems that Only the IPv6 adresss ( :: ) are running, it should also mention something like:
WebServer(HTTP) started on address: 0.0.0.0 with port 8080
Did you do something on this? Do you have another webserver running on this machine? Perhaps try using another port than 8080 with startup parameters eg -www 8090
gixfighter
I only set static IP adress in IPv4 settings, IPv6 is still automatic.
I now got this, when trying 0.0.0.0 it gives permission error:, something to do with permission in network settings? I don't know ...
2022-12-29 12:47:29.655 Status: Domoticz V2022.2 (c)2012-2022 GizMoCuz
2022-12-29 12:47:29.655 Status: Build Hash: eea9db734, Date: 2022-11-05 13:05:35
2022-12-29 12:47:29.655 Status: Startup Path: /home/odroid/domoticz/
2022-12-29 12:47:29.749 Status: PluginSystem: Started, Python version '3.9.5', 1 plugin definitions loaded.
2022-12-29 12:47:29.753 Active notification Subsystems: fcm, http (2/13)
2022-12-29 12:47:29.754 Status: WebServer(HTTP) started on address: :: with port 8080
2022-12-29 12:47:29.761 Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied [system:13], trying ::
2022-12-29 12:47:29.763 Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied [system:13], trying 0.0.0.0
2022-12-29 12:47:29.766 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied [system:13]
2022-12-29 12:47:29.766 Error: WebServer(SSL) check privileges for opening ports below 1024
2022-12-29 12:47:29.768 Starting shared server on: :::6144
2022-12-29 12:47:29.769 Status: TCPServer: shared server started...
2022-12-29 12:47:29.770 Status: RxQueue: queue worker started...
2022-12-29 12:47:31.770 Status: NotificationSystem: thread started...
2022-12-29 12:47:31.770 Status: EventSystem: reset all events...
2022-12-29 12:47:31.771 Status: EventSystem: reset all device statuses...
2022-12-29 12:47:31.815 Status: Python EventSystem: Initializing event module.
2022-12-29 12:47:31.815 Status: EventSystem: Started
2022-12-29 12:47:31.815 Status: EventSystem: Queue thread started...
gixfighter
I eventually decided to start over with newest OS 22.04 and works directly. Not sure if this was a incidental issue or related to latest stable Domoticz with Ubuntu 20.04.
thanks for the help.
OK, good to know it runs again. I myself run Domoticz on a system with Ubuntu 20.04 so that should be no issue.
