Domoticz-Google-Assistant (dzga) Topic is solved
Alexa, Google Home and Siri
kofec
Re: Domoticz-Google-Assistant (dzga)
Post by kofec »
Thanks a lot for quick reply. But probably it needs more modification. One was that I should change http -> https right ? That my fault as I didn't mentioned that I have SSL enabled
second question is regarding token. I have version DZGA Version: 1.10.9 and on settings page only one token is for Ngrok which I'm not using.
and I saw you commit: https://github.com/DewGew/Domoticz-Goog ... /226/files
Maybe you mean this token ? https://github.com/DewGew/Domoticz-Goog ... c8433b7a7c
NilsNijenhuis
Post by NilsNijenhuis »
Hello DewGew and others,
I was working with dzga version 1.10.9 and update to the last master version. but cant sync devices anymore.
tried almost everything and did today a complete new install of the last master version on my raspberry and made a new project on Google.
But in the last step : in the google home app -> connect to [test] Huis
i get the sign in screen of DZGA but after using my username and password i get the following error : Could not reach [test] Huis please try again.
does anyone have a clue what can be the cause?
i am totally clueless.
mark.sellwood
Post by mark.sellwood »
I'm trying to get Chromecast Notifications working, in config.yaml I have Chromecast_Name: LOunge
WHen I open http://dzgaserver:3030/play?doorbell1.mp3 I get the following:-
Page not found!: 'NoneType' object has no attribute 'volume_level'
In the log I see ERROR - Chromecast playmedia unsuccefull, error : Chromecast None:8009 is connecting...
What Am I missing?
Fixed it, needed to add @50 to set the volume
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
DewGew
Domoticz version: V4.10618
Post by DewGew »
NilsNijenhuis wrote: Saturday 24 December 2022 13:11 Hello DewGew and others,
i had restarted the hole pi again after the update and its linked again
DewGew
Post by DewGew »
kofec wrote: Friday 23 December 2022 9:45 Thanks a lot for quick reply. But probably it needs more modification. One was that I should change http -> https right ? That my fault as I didn't mentioned that I have SSL enabled
Correct observation. Its possible to use local ip adresses also if they are in the same network.
NilsNijenhuis
DewGew wrote: Wednesday 28 December 2022 12:59
i restarted dzga -> linking in the home app doesn't work
i restarten my raspberry -> linking in the home app doesn't work
any other tips?
DewGew
Post by DewGew »
NilsNijenhuis wrote: Wednesday 28 December 2022 14:47
any other tips?
Try Goto action on google and press Test button again.
NilsNijenhuis
My DZGA works again, test button and the home grapgh wasn't linked to the correct project
lec668
Domoticz version: 2021.1
Domoticz-Google-Assistant (dzga) chromecast notification
Post by lec668 »
I've been using dzga since the beginning, great job for controling Domoticz ! And many thanks for creating it !
I have trouble adding the chromecast notification to work on my functional dzga.
I assume manual modification of the smarthome.py is no longer necessary (as per Wiki),
as I find the code included in the current version of the script ?
I added Chromecast device or Group to the yaml file, the script display "Starting up chromecasts", domoticz control is still fine.
But when I try somethine like http://dzga-domoticz-ip:port/say?bonjour/fr
I only get
Page not found!: slugify() got an unexpected keyword argument 'only_ascii'
What could go wrong ?
Thanks for helping and merry Christmas
fabry91
Domoticz version: 2022.2
Post by fabry91 »
Good morning guys,
same problem here with DZGA, when I have updated from the web interface to the v1.23.2 master all switches and etc. results offline in the Google Home app and audio control on our Google Nest didn't work.
The problem were later on solved with adding again the DZGA action project from the Google Home app.
The Sync Devices in the web interface of DZGA still don't work.
Thank you
paede
Post by paede »
Fist I want to thank you for this great work.
I used controllicz for a few years, which will end its service in summer.
That's why I decided to take the effort to setup dzga.
I've got most of it working. I have a raspberry pi 3 with domoticz, nginx reverse proxy and dzga running.
First issue:
When I reboot the pi a have to login via putty and restart nginx to get dzga working. nginx is running after the bootup but the connection via XXXXX.mooo.com does not work. When I restart nginx "sudo service nginx restart" it works.
second issue:
when I execute scenes with voice on google home, the scene is executed, but google tells me that there is an error. See dzga-log:
2023-02-20 18:42:15 - INFO - {
  "inputs": [
      "context": {
        "locale_country": "DE",
        "locale_language": "de"
      "intent": "action.devices.EXECUTE",
      "payload": {
        "commands": [
            "devices": [
                "id": "Scene20"
            "execution": [
                "command": "action.devices.commands.ActivateScene",
                "params": {
                  "deactivate": false
  "requestId": "5882158549538026065"
2023-02-20 18:42:15 - INFO - Google Assistant requests an action.devices.EXECUTE
2023-02-20 18:42:22 - ERROR - 400 Client Error: Bad Request for url: https://homegraph.googleapis.com/v1/devices:reportStateAndNotification
2023-02-20 18:42:22 - ERROR - Error handling message {'inputs': [{'context': {'locale_country': 'DE', 'locale_language': 'de'}, 'intent': 'action.devices.EXECUTE', 'payload': {'commands': [{'devices': [{'id': 'Scene20'}], 'execution': [{'command': 'action.devices.commands.ActivateScene', 'params': {'deactivate': False, 'online': True}}]}]}}], 'requestId': '5882158549538026065'}: {'errorCode': 'unknownError'}
Turning on or off a lamp does work without that error.
2023-02-20 19:55:48 - INFO - {
  "inputs": [
      "context": {
      "payload": {
        "commands": [
            "devices": [
                "id": "Light236"
            "execution": [
                "command": "action.devices.commands.OnOff",
                "params": {
                  "on": false
  "requestId": "3097062509886629023"
2023-02-20 19:55:48 - INFO - Google Assistant requests an action.devices.EXECUTE
Do you have an idea how to solve one of these issues?
greets paede
mark.sellwood
dzga in Docker
I'm trying to get dzga working in Docker, I have followed the instructions but end up with an error as follows:
=> ERROR [3/8] RUN mkdir -p config
Im on a Pi with Bullseye
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Docker version 20.10.22, build 3a2c30b
Any pointers please?
paede
Post by paede »
Some things I found during further testing:
this is my nginx sites-enabled/default
server {
    listen 80;
    listen [::]:80;
    server_name heimautomation.mooo.com;
    #change to match your address
    return 301 https://$server_name$request_uri;
server {
        listen 443 ssl;
        listen [::]:443 ssl;
        ssl_certificate /etc/letsencrypt/live/heimautomation.mooo.com/fullchain.pem;
        ssl_certificate_key /etc/letsencrypt/live/heimautomation.mooo.com/privkey.pem;
        #ssl on;
        #ssl_session_cache  builtin:1000  shared:SSL:10m;
        ssl_protocols  TLSv1 TLSv1.1 TLSv1.2;
        ssl_ciphers HIGH:!aNULL:!eNULL:!EXPORT:!CAMELLIA:!DES:!MD5:!PSK:!RC4;
        ssl_prefer_server_ciphers on;
        location / {
                proxy_set_header Host $host;
                proxy_set_header X-Real-IP $remote_addr;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-Scheme $scheme;
                proxy_pass http://localhost:3030; #Local ipno to dzga
                proxy_read_timeout  90;
location /domoticz/ {
      rewrite ^/domoticz/?(.*) /$1 break;
      proxy_pass http://localhost:8080; #local ipno to domoticz
location /assistant/ {
      rewrite ^/assistant/?(.*) /$1 break;
      proxy_pass https://localhost:3030; #local ipno to dzga
to access domoticz via https://heimautomation.mooo.com/domoticz I had to ad a second / --> location /domoticz/ {
now that connection is working
I tried the same for the google connection --> location /assistant/ {
then I realized that I had https://heimautomation.mooo.com/smarthome (or /oauth or /token) in google action console.
I changed that to https://heimautomation.mooo.com/assistant/smarthome (etc.)
But now when I try to ad the [test]DomoticzVerbindung app I get a "502 Bad Gateway" error.
The same when I use a webbrowser with https://heimautomation.mooo.com/assistant/settings
when I remove the s in nginx default settings on "proxy_pass https://localhost:3030;" the domoticz-google-assistant settings page loads and the [test]DomoticzVerbindung connects. (not as stated in aditional settings https://github.com/DewGew/Domoticz-Goog ... erse-proxy)
I can:
  • access domoticz with https
  • turn on/off lamps via google home
  • activate scenes via google home (but still got the error message)
to be solved:
  • get rid of the error message
  • nginx service needs to be restarted after a reboot to use dzga
  • add and connect the [test]DomoticzVerbindung to my wifes google home app
  • [test]DomoticzVerbindung in my wifes google home app has only 1 device connected (instead of 105 devices)
update: I changed "proxy_pass https://localhost:3030; #local ipno to dzga" to "proxy_pass https://127.0.01:3030; #local ipno to dzga" now there is no restart of the service needed after a reboot.
What can I do to get all devices recognized in my wifes google home app?`
How can I get rid of the "error message"?
as I did not get any response here in the forum for my issues with dzga, I decided to give node-red and node-red-contrib-google-smarthome a try (https://flows.nodered.org/node/node-red ... -smarthome)
after a few hours to understand how nodered works, I got everything working fine. I can execute scenes without any error messages :-)
kofec
Post by kofec »
DewGew wrote: Wednesday 28 December 2022 13:49
Can someone was able to authenticate via token ? Can give example of script (curl, wget, python script)? I tried:
curl -v --insecure -H 'Accept: application/json' -H "Authorization: Bearer aAaAaAaAaAaAaAaAaAaA" https://192.168.100.150:3030/sync
*   Trying 192.168.100.150:3030...
* TCP_NODELAY set
* Connected to 192.168.100.150 (192.168.100.150) port 3030 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* ALPN, server did not agree to a protocol
* Server certificate:
*  subject: CN=...............
*  start date: Mar  1 10:19:19 2023 GMT
*  expire date: May 30 10:19:18 2023 GMT
*  issuer: C=US; O=Let's Encrypt; CN=R3
*  SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
> GET /sync HTTP/1.1
> Host: 192.168.100.150:3030
> User-Agent: curl/7.68.0
* Mark bundle as not supporting multiuse
* HTTP 1.0, assume close after body
< HTTP/1.0 307 Temporary Redirect
< Server: BaseHTTP/0.6 Python/3.11.1
< Date: Wed, 08 Mar 2023 18:23:16 GMT
< Location: login?redirect_uri=sync
* Closing connection 0
* TLSv1.2 (OUT), TLS alert, close notify (256):
DewGew
Post by DewGew »
kofec wrote: Wednesday 08 March 2023 19:39
* TCP_NODELAY set
* ALPN, offering h2
> GET /sync HTTP/1.1
Make sure you are using https POST method not http GET.
kofec
Post by kofec »
Thanks again for reply I found a solution:
https://github.com/DewGew/Domoticz-Goog ... issues/308
kofec
Post by kofec »
And it is working fine now:
curl -v --insecure -H 'Accept: application/json' -H "Authorization: Bearer aAaAaAaAaAaAaAaAaAaA" --data "SYNC" -X POST https://192.168.100.150:3030/sync
Synchronization request sent, status_code: True
meal
Domoticz version: 2025.2
Post by meal »
1 - Context of the issue:
Domoticz on RPI3B
Version: 2023.1 (build 15182)
Build Hash: 34815c1a9-modified
Compile Date: 2023-04-10 17:22:59
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Oct 31 2022, 14:04:00) [GCC 8.3.0]
Domoticz-Google-Assistant 1.23.2
2 -Description of the issue
I have 50 devices in Domoticz version 2022.1 which are interfaced with Domoticz-Google-Assistant v1.11.10
The interface was operating correctly so far.
I have upgraded Domoticz to version 2023.1 and DZGA to 1.23.2.
Since then for a set of devices of type "doorlock", "Selector" I can voice control the devices and it reflects correctly in Domoticz but I get the error
"ERROR - 400 Client Error: Bad Request for url: https://homegraph.googleapis.com/v1/dev ... tification" in DZGA.LOG and the state is not reflected in Google Home which creates discrepancies between Domoticz and Google Home.
If anybody has implemented DZGA with Domoticz 2023.1 and managed to run correctly such devices of these subtype I would be interested to share the configuration.
I would be keen to share any hint to fix the issue.
Many thanks in advance
BR
meal
Xavier82
Domoticz version: 2023.2
Post by Xavier82 »
Did you checked the wiki?
https://github.com/DewGew/Domoticz-Goog ... figuration:
Light or Switch devices can choose types from:
light, ac_unit, bathtub, coffeemaker, doorbell, dishwasher, dryer, fan, heater, kettle, media, microwave, outlet, oven, speaker, switch, vacuum, washer, waterheater, window, door, gate, garage.
For heater, kettle, waterheater, oven you can still use merge_thermo_idx to merge thermostat to control temperature.
Door Contact devices can choose window, gate or garage.
Blind devices can choose window, door, gate or garage.
Selector devices can choose only vacuum
Pushbutton devices can choose doorbell, light, outlet
These are the supported devices.
Did it worked before the upgrade of Domoticz and DZGA?
meal
Post by meal »
Yes it was working perfectly in the previous version of Domoticz 2022.1 which are interfaced with Domoticz-Google-Assistant v1.11.10
"Door Lock" does not work any longer.
BR
meal
