sent parameter not passing
All kinds of 'OS' scripts
Gianni
Post by Gianni »
hello
I'm converting the philips tv script to use in a docker envoirement.
Everythings is working now except passing parameters.
It's seems that the parameter is not sending with the script:///
if i add a simple line to a test bash file like
python3 /opt/domoticz/scripts/pylips/pylips.py --host $host --user $user --pass $pass --command mute
and run this from my selector
script:///opt/domoticz/scripts/test.sh
then my tv will mute en unmute so thats working
but if i working with multiple commnands and a switch then the arg is not passing
echo $1
case $1 in
standby)
python3 $path --host $host --user $user --pass $pass --command standby &
exit 0
power_on)
python3 $path --host $host --user $user --pass $pass --command power_on &
exit 0
mute)
python3 $path --host $host --user $user --pass $pass --command  mute &
exit 0
and run this in the selector
script:///opt/domoticz/scripts/pylips/tvphilips.sh mute
then it's not working.
In my log i also not seeing the argument passing?
 2022-12-20 17:57:03.944 Status: User: Admin (IP: xxx.xxx.xxx.xxx) initiated a switch command (323/test/Set Level)
2022-12-20 17:57:04.186 Status: Executing script: /opt/domoticz/scripts/pylips/tvphilips.sh
any idea?
Gianni
Re: sent parameter not passing
Post by Gianni »
fix it with KISS
Delete everything and restart
remove the case and passing the correct command direct to script
script:///opt/domoticz/scripts/pylips/test.sh volume_down
Script
echo -n "Parameter is  $1"
host=xxx.Xxx.xxx.xxx
user=xxxxxxxxxxxxxxxxx
pass=xxxxxxxxxxxxxxxx
path=/opt/domoticz/scripts/pylips/pylips.py
echo -n $host
echo -n $user
echo -n $pass
echo -n $path
python3 $path --host $host --user $user --pass $pass --command $1
Now i need to find the solution for my next problem.
The selector does not allow to let me volume up multiple time's
