Use garage door opener to set switch?
JeroenG
Domoticz version: 20231
Post by JeroenG »
To open the garage door we have a hand-transmitter with 4 buttons. According the print on the backside is operates on 868.3 mhz.
Button 1 is used for the garagedoor, the other buttons are not used, so I see some oppertunities. What do I need to get the signal into domotic if 1 of the buttons is pressed?
Probably some kind of receiver, but then the signal needs to be send into Domoticz to flip a switch (or start a script).
Any suggestions/tips and/or pitfalls?
Thanks,
Jeroen
EddyG
Re: Use garage door opener to set switch?
Post by EddyG »
https://www.nodo-shop.nl/nl/42-rflink-868 but there is no guaranty that the signal will be decoded for Domoticz.
Search this forum for the type of the transmitter. May be somebody already found the solution.
rgroothuis
Post by rgroothuis »
I had something similar, also a garagedoor remote control which sends out a RF signal.
What I did to automate this, to control this from Domoticz is to use a Fibaro Smart Implant (https://www.fibaro.com/nl/products/smart-implant/). This small device has 2x potential-free outputs (for controlling external circuits), I soldered two wires over the buttons on the remote control and added the Fibaro to Domoticz and now I can control the garage door through Domoticz. Works perfectly and stable :-)
JeroenG
Post by JeroenG »
Probably will look into the solutions EddyG mentionend.
@rgroothuis, my requirement is just the other way around, I want to use the garage opener to activate a switch in Domoticz, not control the garage from Domoticz.
Happy new year,
Jeroen
galinette
Post by galinette »
I had the same need. I purchased an extension to my Hormann garage door opener which provides input/output dry contacts for getting the door state and triggering open/close. And I added the Fibaro Smart implant inside. This means I have an input to check the door state, and two inputs for opening and closing, in ZWave. Works like a charm.
