I am completly new to DZVents so perhaps I ask something that is asked before.
I have a electric boiler that has to start when the solar panels produce enough power.
With a Blocky this works. But when there is only for 1 minute enough sunshine the boiler is switched on.
So I am looking for an option to use a moving average.
I see in DzVents the option smoothItem.
Could somebody show how this is done? I get mixed up by all the options in DzVents...
thanks in advance,
Har
smoothing values
- Domoticz version: 2025.1
Re: smoothing values
You have to use history=true. See the examples for this in the documentation on persistent data.
See for example viewtopic.php?p=144660
har0543
- Domoticz version: 2022.2
Thank you for your reply. But I can not see the trees in the forest...
I am sorry but the history=true function does not make sense to me. But I have zero programming knowlage.
I have an divice called "teruglevering" which gives values in Watts.
Do i first have to make some kind off extra logging with 10 values and another script that calcutales a new divice called pa "smoothed terugleveering"
Is there a book or site in dutch that explense LUA and or DzVents?
Hope somebody can help me here
Here you have an example of a script using the same functionally, only using .avg() instead of smootItem().
viewtopic.php?p=288575
