Shelly Pro4PM and MQTT Python Plugin
ChrisVH1982
Post by ChrisVH1982 »
Last week I reinstalled Domoticz, imported the existing DB and installed again latest MQTT Plugin for Shelly (https://github.com/enesbcs/Shelly_MQTT).
I just received a Shelly Pro 4 PM which according to the compatibility list is supported by the MQTT plugin. But buttons and power indicators won't turn up on Domoticz as they used to when I were to configure other Shellies. Anyone an idea what is the point?
FireWizard
Re: Shelly Pro4PM and MQTT Python Plugin
Post by FireWizard »
Hi, @ChrisVH1982,
A quick view to the plugin, indicates that this one is made for Generation 1 Shelly devices, while your brand new Shelly Pro4PM is, as far as I know, a Generation 2 device.
Have a look at this thread: viewtopic.php?f=65&t=25656
ChrisVH1982
Hi! The "Shelly4 Pro (relay)" is listed as supported device. So I was hoping that I can use it.
FireWizard
Hi @ChrisVH1982,
I do not own a Shelly Pro 4 PM, so I cannot tell you from practical experience.
I took the information from the README of the corresponding Node-RED node.
See: https://flows.nodered.org/node/node-red-contrib-shelly
I do not see it in the list, shown at https://shelly-api-docs.shelly.cloud/gen1/#wifi-modes
But I do find it here: https://shelly-api-docs.shelly.cloud/ge ... ellyPro4PM
Conclusion: this is a Gen 2 device
If I look to your plugin https://github.com/enesbcs/Shelly_MQTT, I do not see the Shelly Pro 4 PM mentioned.
I do see the
Shelly4 Pro (relay)*
But that is a different device.
As far as I know, a new plugin for Gen 2 Shelly devices does not exist (yet), so you might want to try the Node RED flow with that Gen 2 node or using MQTT.
wbouwens
Post by wbouwens »
Have you got the 4pm working with mqtt?
mk01
Post by mk01 »
wbouwens wrote: Saturday 03 December 2022 21:41 Have you got the 4pm working with mqtt?
you can try
https :// github com /mk01/shelly-2to1-mqtt
wbouwens
Post by wbouwens »
Hi Mk,
i installed your script in the shelly. Switches are now coming up. But not the power meters.
mk01
Post by mk01 »
wbouwens wrote: Monday 02 January 2023 0:08 Hi Mk,
true, bug. please take the latest version.
(if you would see updates only to power or only to energy, then most probably Shelly-MQTT's update limiter is kicking in (energy/power is one device and limiter passes only 1 change in 10sec. in that case try changing very last line of the script):
Timer.set(12000, true, reportDevice, "power");
to
Timer.set(24000, true, reportDevice, "power");
mk
