enphase envoy with (HTTP) interface
smaus
i try to connect my envoy with domoticz bij i get a error error: enphaseapi: invalid data reseived!
Can someone help me with this.
many thanks
many thanks
- FireWizard
Re: enphase envoy with (HTTP) interface
@smaus,
You wrote:
I assume that you use or try to use the Enphase hardware in Domoticz?
Which type of Envoy do you have installed?
Standard version? Or the "metered" version? Or even any other model? Is it a new installation or older?
Has it been working before?
At least.
Take your favorite browser and go to the following URL: http://<IP address of your Envoy> /production.json and check that you get some data, similar to the picture below:
What you will see is the number of connected and active inverters. In this picture 8.
Also the produced Power at the moment (1224 W) and also the total production during lifetime in Wh.
I assume you do not have a AC battery connected, for local storage.
In case of a "metered" version, you will see more data.
Check it and report back.
@smaus,
You wrote:
At least we can try, but I need a little bit more information.i try to connect my envoy with domoticz bij i get a error error: enphaseapi: invalid data reseived!
At least.
smaus
Which type of Envoy do you have installed? Standard version? Or the "metered" version? Or even any other model?
this one is intalled
4 years old
no i try to make it work
Take your favorite browser and go to the following URL: http://<IP address of your Envoy> /production.json and check that you get some data.
this is not working for me.
regards
4 years old
regards
- FireWizard
@smaus
The one you have installed is neither an Enphase Envoy-S, nor an Enphase Envoy-S metered, but an Enphase Envoy ENV-120 M Communication Gateway.
The Domoticz hardware, as far as I know, does not support this older version.
I couldn't find any information on how to access it.
Some data I found at: http://hackadayarchive.com/viewtopic.php?f=10&t=4324
Perhaps this give you some indication. Check also the other links in the bottom.
Another way to get data into Domoticz is to use the same approach, as described at: https://www.domoticz.com/forum/viewtopic.php?t=22368
smaus
Oke
Thanks for the info
Thanks for the info
Mat2Vence
- Domoticz version: 3.7449
I have the same error message when I am trying to connect to my Envoy-S metered.
When I am checking <ip adress>/production.json I am getting the following data :
Thanks for your help.
{"production":[{"type":"inverters","activeCount":2,"readingTime":1652118271,"wNow":24,"whLifetime":1845},{"type":"eim","activeCount":1,"measurementType":"production","readingTime":1652118343,"wNow":23.768,"whLifetime":1879.585,"varhLeadLifetime":0.0,"varhLagLifetime":907.098,"vahLifetime":3219.018,"rmsCurrent":0.358,"rmsVoltage":238.78,"reactPwr":34.708,"apprntPwr":87.515,"pwrFactor":0.36,"whToday":1794.585,"whLastSevenDays":1879.585,"vahToday":2711.018,"varhLeadToday":0.0,"varhLagToday":684.098}],"consumption":[{"type":"eim","activeCount":1,"measurementType":"total-consumption","readingTime":1652118343,"wNow":3067.718,"whLifetime":12240.048,"varhLeadLifetime":10593.636,"varhLagLifetime":2.83,"vahLifetime":20591.518,"rmsCurrent":13.813,"rmsVoltage":238.697,"reactPwr":-224.892,"apprntPwr":3108.486,"pwrFactor":0.99,"whToday":7804.048,"whLastSevenDays":12132.048,"vahToday":14591.518,"varhLeadToday":8131.636,"varhLagToday":2.83},{"type":"eim","activeCount":1,"measurementType":"net-consumption","readingTime":1652118343,"wNow":3043.95,"whLifetime":0.0,"varhLeadLifetime":10593.636,"varhLagLifetime":-904.268,"vahLifetime":20591.518,"rmsCurrent":13.454,"rmsVoltage":238.738,"reactPwr":-190.184,"apprntPwr":3212.084,"pwrFactor":0.95,"whToday":0,"whLastSevenDays":0,"vahToday":0,"varhLeadToday":0,"varhLagToday":0}],"storage":[{"type":"acb","activeCount":0,"readingTime":0,"wNow":0,"whNow":0,"state":"idle"}]}- FireWizard
Hello @Mat2Vence
You wrote:
Do you connect to the Enphase "hardware" in Domoticz? and you see the error message in the Domoticz log?
If I check your data, I do not see anything wrong and it is equal to what Domoticz is expecting
Do you receive the message every 30 seconds? Or is it sometimes?
Domoticz version?
Operating system?
You wrote:
Do you mean "enphaseapi: invalid data received!"?I have the same error message when I am trying to connect to my Envoy-S metered.
Domoticz version?
Operating system?
Last edited by FireWizard on Wednesday 07 September 2022 16:01, edited 1 time in total.
Mat2Vence
Thanks for the reply.
I am getting the error message in the log every 30 seconds "Error: Envoy: EnphaseAPI: Error getting http data!"
The hardware is setup in Domoticz with the correct IP address. Looks strange to me but don't know how to investigate.
- FireWizard
@Mat2Vence,
What is your Domoticz version? 3.7449?
Mat2Vence
Here is details ;
Version: 2022.1
Build Hash: c9526851b
Compile Date: 2022-01-31 09:34:32
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
It is running on a RPi4.
Version: 2022.1
- FireWizard
Hi @Mat2Vence,
I'm aware of one issue, that happened about 3 years.
See: https://github.com/domoticz/domoticz/pull/3378
Since then I have not seen any reports.
But your error message is different (Error getting http data) and not invalid data received.
So I don't think it is the same.
Port setting is correct? (80)
Mat2Vence
I've wasted your time.... basic error from my side.. apologize!!
I put http:// in the IP filed! Agrrrrr!!
Coming back to the IP itself only, that's working better!!
Sorry for this and thanks all for your support
- FireWizard
@Mat2Vence,
Don't worry.
These things just happens, but a discussion on the forum, made that you looked once more.
Good, that it is solved.
Could you mark this topic as solved?
Don't worry.
Mat2Vence
I am not the initiator of the topic so I can't edit it.
TurboX
Regarding this official support, it seems not working with new firmware 7.x.
Someone can confirm this?
In my side with firmware D7.0.88.220117, it doesn't work (Error getting http data) and a direct access require the Enphase login.
(tried with @waaren Dzevent without success too)
- FireWizard
Hi @TurboX,
See https://support.enphase.com/s/question/ ... -to-envoys
See also the Home Assistant forum:
https://community.home-assistant.io/t/e ... 8ea/314452
I do not have version 7 (yet), so I cannot test. If someone can test.
TurboX
Hi @FireWizard
Yes and it seems that some solutions are found for HA (curl authentification / MQTT integration) if I understand well.
By example: https://community.home-assistant.io/t/e ... 328668/577
TurboX
If a developper is motivated and own an Envoy with 7.X firmware, I think these link could help:
https://github.com/dlmcpaul/EnphaseColl ... -973656321
https://github.com/edasque/enphaseLocal ... ation-flow
TurboX
I have install Home Assistant for testing purpose and I confirm that it is possible in firmware V7 to have a local acces to production (and for each solar panel).
The pluging which works: https://github.com/briancmpbll/home_ass ... stom_envoy
- gizmocuz
There have been made some changes recently and it is now also possible to use V7 with the native Enphase implementation in Domoticz
