Netatmo refresh time since 2022.2
dgilbert2
Domoticz version: 2024.7
Post by dgilbert2 »
I see that Domoticz stable 2022.2 has changed the Netatmo data refresh time from 10 minutes to 15 minutes. How can I change this back to 10 please?
15 minutes is out of step with Netatmo itself (refreshing every 10 minutes) and so when using Netatmo temperature data to control devices (eg heaters) it causes more of a control lag which is quite noticeable.
tonk
Re: Netatmo refresh time since 2022.2
Post by tonk »
I've the same problem/question.
Workaround: at the hardware settings of the Netatmo: set the Hardware timeout to eg 15min
dgilbert2
Post by dgilbert2 »
tonk wrote: Saturday 19 November 2022 14:31 I've the same problem/question.
Thanks for that, will give it a go set at 10minutes.
