Thanks, I'm gonna study it
No, this is not part of the standard implementation, but since the inline-reply option in Telegram, I guess you should be able to build that in a script.
I sent you in messages, the last lines where the error appears
/usr/bin/lua5 .2: error loading module 'ssl .core' from file '/usr/local/lib/lua/5 .2/ssl .so':
libssl .so .1 .0 .0: cannot open shared object file: No such file or directory
stack traceback:
[C]: in ?
[C]: in function 'require'
/usr/local/share/lua/5 .2/ssl .lua:7: in main chunk
/usr/local/share/lua/5 .2/ssl/https .lua:10: in main chunk
/home/pi/dtgbot/dtgbot .lua:132: in main chunk
[C]: in ?
sudo dpkg -i libssl1 .0 .0_1 .0 .1t-1+deb8u8_armhf .deb
dpkg: regarding libssl1 .0 .0_1 .0 .1t-1+deb8u8_armhf .deb containing libssl1 .0 .0:armhf, pre-dependency issue:
libssl1 .0 .0 pre-depends on multiarch-support
multiarch-support is not installed.
dpkg: error processing archive libssl1 .0 .0_1 .0 .1t-1+deb8u8_armhf .deb (--install):
pre-dependency problem - not installing libssl1 .0 .0:armhf
Errors were encountered while processing:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package libssl1 .0 .0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libssl1 .0 .0' has no installation candidate
