Hama Smart Radiator Thermostat (TS0601) Topic is solved
kris
Domoticz version: 2023.1
Post by kris »
Hi.
I picked up this Hama TRV https://zigbee.blakadder.com/Hama_00176592.html.
It is listed as compatible but it won't report any data and I can't set a setpoint or change mode from Domoticz.
It was added without any errors:
2022-11-21 17:30:57.254 Status: PiZiGate: [None] NEW OBJECT: 61e9 None
2022-11-21 17:30:57.576 Status: PiZiGate: [-] NEW OBJECT: 61e9 Active Endpoint Response Ep: 01 LQI: 99
2022-11-21 17:30:57.590 Status: PiZiGate: [-] NEW OBJECT: 61e9 Request Simple Descriptor for Ep: 01
2022-11-21 17:30:58.035 Status: PiZiGate: [-] NEW OBJECT: 61e9 Simple Descriptor Response EP: 0x01 LQI: 84
2022-11-21 17:30:58.037 Status: PiZiGate: [-] NEW OBJECT: 61e9 ProfileID 0104
2022-11-21 17:30:58.038 Status: PiZiGate: [-] NEW OBJECT: 61e9 ZDeviceID 0051
2022-11-21 17:30:58.039 Status: PiZiGate: [-] NEW OBJECT: 61e9 Application Version 0001
2022-11-21 17:30:58.041 Status: PiZiGate: [-] NEW OBJECT: 61e9 Cluster IN Count: 04
2022-11-21 17:30:58.043 Status: PiZiGate: [-] NEW OBJECT: 61e9 Cluster In 1: 0000 (Basic)
2022-11-21 17:30:58.044 Status: PiZiGate: [-] NEW OBJECT: 61e9 Cluster In 2: 0004 (Groups)
2022-11-21 17:30:58.046 Status: PiZiGate: [-] NEW OBJECT: 61e9 Cluster In 3: 0005 (Scenes)
2022-11-21 17:30:58.048 Status: PiZiGate: [-] NEW OBJECT: 61e9 Cluster In 4: ef00
2022-11-21 17:30:58.049 Status: PiZiGate: [-] NEW OBJECT: 61e9 Cluster OUT Count: 02
2022-11-21 17:30:58.051 Status: PiZiGate: [-] NEW OBJECT: 61e9 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2022-11-21 17:30:58.053 Status: PiZiGate: [-] NEW OBJECT: 61e9 Cluster Out 2: 000a (Time)
2022-11-21 17:30:58.125 Status: PiZiGate: [0] NEW OBJECT: 61e9 Model Name: TS0601
2022-11-21 17:30:58.127 Status: PiZiGate: [0] NEW OBJECT: 61e9 Manufacturer Name: _TZE200_yw7cahqs
2022-11-21 17:30:58.138 Status: PiZiGate: [None] NEW OBJECT: 61e9 Request Node Descriptor
Any idea how to get it working?
Domoticz 2023.2: Raspberry Pi 2B: Raspbian 11 Bullseye / Z-Wave JS 12.4.1 (docker): Aeotec Z-stick gen5 / Zigbee for Domoticz 7.1.007 [3.174]: PiZiGate 0321 / RFLink 1.48
pipiche
Re: Hama Smart Radiator Thermostat (TS0601)
Post by pipiche »
can you try to update to 6.4.025
remove all domoticz widgets created for this Thermostat
restart the plugin
and redo the pairing
kris
Post by kris »
Wow, it works perfectly now!
Thank you so much for fixing it so quickly. Amazing work on this plugin :)
pipiche
Post by pipiche »
thanks for the nice words
