Small LUA script for switching off an infrared panel in our bathroom after 45 minutes
ubfssF
Domoticz version: 2.2364
Post by ubfssF »
As some people in our household tend to forget putting off the panel after usage :?, which is switched on/off by a switch that's also controlled by Domoticz , I am using this script as a backup-measure:
-- script_time_infraredpanel.lua
t1 = os.time()
s = otherdevices_lastupdate['Badkamer infraroodpaneel']
-- returns a date time like 2013-07-11 17:23:12
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
-- 45 minutes translates to 2700 seconds, after being on for that time, the panel is switched off and a notification is send (if concigured in Domoticz)
if (otherdevices['Badkamer infraroodpaneel'] == 'On' and difference > 2700 and difference < 2710) then
   commandArray['SendNotification']='Infrarood paneel melding#Het paneel staat meer dan 45 minuten aan en gaat nu uit!'
   commandArray['Badkamer infraroodpaneel']='Off'
It is based on a garage-door script by someone else in this forum.
