Domoticz installation on a Linux Mageia Distro
Sylv01
Post by Sylv01 »
Hello guys, sorry for my bad English, but I'm french man ! :D
I'm trying to install domoticz into a linux distribution, called Mageia, and I have a pb.
During checking, installation stop after this message :
:::    Checking for domoticz_DEP...[root@localhost sylvain]#
What is "domoticz_DEP", it's an environment variable ?
How can I setting it ?
Many thanks in advance !
FireWizard
Re: Domoticz installation on a Linux Mageia Distro
Post by FireWizard »
Is there something on/after the dots (...) after domoticz_DEP?
During installation domoticz checks if the requirements for dependencies are for filled.
Obviously not.
Sylv01
Post by Sylv01 »
FireWizard wrote: Wednesday 16 November 2022 11:46 Hi,
Obviously not.
Hello, thanks for your reply !
No, there are nothing after dots, only my prompt, as mentioned...
FireWizard
HI @Sylv01
Which RPM package did you install. Where does it come from?
Sylv01
Post by Sylv01 »
I'm only using installation procedure like that :
[root@localhost ~]# sudo curl -L install.domoticz.com | bash
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   178  100   178    0     0   3825      0 --:--:-- --:--:-- --:--:--  3869
100 16364  100 16364    0     0  95860      0 --:--:-- --:--:-- --:--:-- 95860
::: You are root.
::: Verifying free disk space...
grep: warning: stray \ before /
::: Checking dnf for upgraded packages....egrep: warning: egrep is obsolescent; using grep -E
 done!
::: Your system is up to date! Continuing with Domoticz installation...
:::    Checking for procps-ng... installed!
:::    Checking for newt... installed!
:::    Checking for git... installed!
:::    Checking for curl... installed!
:::    Checking for libcurl4... installed!
:::    Checking for unzip... installed!
:::    Checking for wget... installed!
:::    Checking for findutils... installed!
:::    Checking for cronie... installed!
:::    Checking for sudo... installed!
:::    Checking for domoticz_DEP...[root@localhost ~]#
FireWizard
The installation method, you used is an old method and was used for Ubuntu (Debian) based systems.
The new method, you may find at: https://www.domoticz.com/wiki/Linux
The correct command is: sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
However this is still for Ubuntu based systems.
You might know Mageia is one of the forks of Mandriva, which is on its turn the successor of Mandrake Linux, which is again a fork of Red Hat.
Mageia still uses the RPM package system and not apt. (apt-get)
You might look for a RPM package. perhaps one of the latest Fedora packages.
But I don't think version 2022-2 is available. At least I could not find it.
Sylv01
Post by Sylv01 »
Ok thanks, I'm trying the new method, same result...
On the installation script, you can see that there is a verification between Debian based systems (who use apt-get) and Red-Hat based systems, using dnf.
However, Mageia use dnf, so I think it is not really the problem, but a missing dependencies, I don'y know wich.
So, my best way is looking for a domoticz rpm, not really a pb if there isn't last update...
It's strange because I remember that I have red somewhere on this forum, that a guy is using domoticz on Mageia...
FireWizard
Hi @Sylv01
I saw this as well, but its post is from January 2017. So quite old.
You have to find the correct RPM
