I have a question about this item:
https://www.philips-hue.com/es-es/p/hue ... 5#overview
and the philips hue hub.
Someone have this wall switches?
this is supported in domoticz?
It will be very interesing if this switches are detected in the hue integration, but i cant find information about this switch
EDIT:
i can buy one pair of it, no problem to buying it. If some developer helps me to obtain information to add to the integration
thanks
[question] philips hue hub support wall switch
DAVIZINHO
Re: [question] philips hue hub support wall switch
Hello again,
I bought a couple of this switchs today.
Domoticz detect it as selector switch.
When you push it, the selector switches at 10% level as "Button 1".
Every time you push the button, the selector active this 10% level. The switch never change to off. You can change it to off or auto off.
The problem to use this in domoticz is the timing. Exist a big delay between you push de button, and domoticz detect this push. I donw know what is the problem, maybe the philiphs hue hub is the problem of the delay, but its imposible to use.
With a hue bulb it works great, you push the button and the bulb turn on at the moment.
- Domoticz version: 2025.1
Are you using Zigbee2MQTT? As the device has various modes...
https://www.zigbee2mqtt.io/devices/929003017102.html
DAVIZINHO
Nop, im using the Philips hue hub.waltervl wrote: Monday 14 November 2022 10:03 Are you using Zigbee2MQTT? As the device has various modes...
My domoticz its in docker in other floor that the devices
