Lua Script for turning light on when motion
leby
Re: Lua Script for turning light on when motion
Post by leby »
Hej, change 'Set Level 100' to 'On' then it should work. Is it a dimmer or an on/off switch?
if (devicechanged['Badrum-Motion'] == 'Motion' and otherdevices['Badrum-Belysning'] == 'Off') then
        commandArray['Badrum-Belysning']='On'
print('Badrum-Belysning on!')
/lennart
Chopper_Rob
Post by Chopper_Rob »
The reason that the print command does work is that it is outside of the if statement. So every time the script runs it will always log to the event log. Put the print command before the end statement to make it dependent of the if statement.
leby
Post by leby »
Sorry, didnt see first time, a motion sensor is normally indicated as "On" not as "Motion"
if (devicechanged['Badrum-Motion'] == 'On' and otherdevices['Badrum-Belysning'] == 'Off') then
End
or
if (devicechanged['Badrum-Motion']  and otherdevices['Badrum-Belysning'] == 'Off') then
End
which motion sensor do you have?
/lennart
pvm
Domoticz version: 4.10538
Post by pvm »
Wouldn't it be easier to use blocky events to do this?
leby
Post by leby »
Blockly would definitely be easier but perhaps not so fun :D
The problem with your script now is that you want the time to be more than 23 and less than 8, a bit tricky I would say if you start to think about it ;)
If you change the 'and' to 'or' you would cover the time period you intend. You want the time to be 23,24, or 1,2,3,4,5,6,7,8
I have not tested the code below but I think it should work, If you want to use time in your lua script I suggest you spend a few minutes looking in to this site http://www.lua.org/pil/22.1.html
hour = (os.date('%H'))
if 	(devicechanged['Badrum-Motion'] == 'On' and (hour >= 23 or hour < 8) and otherdevices['Badrum-Belysning'] == 'Off') then
	commandArray['Badrum-Belysning']='Set Level 50'
	print("Badrum Belysning on 50%")
	commandArray['Badrum-Belysning']='Set Level 100'
	print('Badrum Belysning on 100%')
/lennart
pvm
Post by pvm »
Agree Leby,
The script you provide is missing something, the else will work for all checks provided. I think you need need an if for the switches and within the then statement another if with checks on time
simonrg
Domoticz version: 3.8807
Post by simonrg »
You could have a look at http://www.domoticz.com/wiki/Smart_Lua_ ... _Smart_PIR for examples of doing this.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
leby
Post by leby »
As simonrg say, the smart pir might be better but, if you want to do what you wrote in the first post you could do like the code below, I have tested it with a dummy device and its working as you intended with the twist that it turns off the light after 5 minutes, you can take that code part out if you wish to turn off manually.
-- the script turns on the dimmer for 5 minutes, the level during daytime is 100 and night 50
h = tonumber((os.date('%H')))
if  	(h >= 8 and h < 23) then
	x = 'Set Level 100 FOR 5'
	x = 'Set Level 50 FOR 5'
	commandArray['Badrum-Belysning']= x
	print(x)
/lennart
cpighin
Domoticz version: 3.8153
Post by cpighin »
:) I'm going to insert my issue into this topic instead of creating a new one
As a first step for learing LUA funcionality I would light a lamp connected to a FibaroSwitch (Switch1) when my Fibaro Motion Sensor (OcchioMagicoFibaro-PIR) detects a movement.
I have created a simple lua file script_device_LightOnAfterMovement.lua
print('this will end up in the domoticz log')
if (devicechanged['OcchioMagicoFibaro-PIR'] == 'On' then
	commandArray['Switch1']='On'
and the lamp does not light when moving in front of the MotionSensor.
Where am I wrong?
Claudio :)
simonrg
Post by simonrg »
cpighin wrote::) I'm going to insert my issue into this topic instead of creating a new one
Where am I wrong?
Claudio :)
You are missing a closing bracket on your if line:
if (devicechanged['OcchioMagicoFibaro-PIR'] == 'On') then
        print('Motion detected')
cpighin
Post by cpighin »
Where am I wrong?
Claudio :)
I corrected my error and tested the file which now works quite fine lighting the lamp.
I note that the action is not immediate and some times the Switch1 goes on status On after tens of seconds or doesen't act at all. Is this normal?
Claudio :)
cpighin
Post by cpighin »
:) I have done few test and realized that the LUA script works always fine (the lamp light on if a movement is detected) only if
- Dashboard shows both devices OcchioMagicoFibaro-PIR and Switch1 in the state: Off
- a movement is perceived by the Motion Sensor (OcchioMagicoFibaro-PIR)
If OcchioMagicoFibaro-PIR is in status On (with Switch1 in status On or Off), the system doesn't reacts.
I believe this is exactly what is expected Domoticz does. If not, please advice me ;)
I observed also that the status of my OcchioMagicoFibaro-PIR changes automatically from On to Off after 30 sec. if no further movement is detected (I guess this parameter can be changed in the configuration file).
After learning how to use a LUA script , I would like to improve it to ensure that the lamp comes on when the sensor detects motion and stays on unless no movements are detected for 2 minutes.
Can you help me?
Claudio :)
simonrg
Post by simonrg »
cpighin wrote:After learning how to use a LUA script , I would like to improve it to ensure that the lamp comes on when the sensor detects motion and stays on unless no movements are detected for 2 minutes.
Not wishing to repeat myself, but you now seem to be trying to do exactly what the Smart Lua Scripts were designed for so have a look at http://www.domoticz.com/wiki/Smart_Lua_ ... _Smart_PIR, basically will keep a light on for a defined length of time after last motion detection and can be configured by the way you name the PIR in Domoticz.
pvm
Post by pvm »
You can also use setting 6 in your fibaro 'eye', no need for lua (though it is nice to learn something new
cpighin
Post by cpighin »
simonrg wrote:Not wishing to repeat myself, but you now seem to be trying to do exactly what the Smart Lua Scripts were designed for so have a look at http://www.domoticz.com/wiki/Smart_Lua_ ... _Smart_PIR, basically will keep a light on for a defined length of time after last motion detection and can be configured by the way you name the PIR in Domoticz.
Tanks simong :)
I was tryong to follow yor suggestion and I encountered the first obstacle on undesrstanding what exactly to do.
In the link mentioned I read
Adding Turning Off Functionality[edit]
First in Domoticz add a new Siemens PIR and call it after a light in your house, say the "Study" light, so the PIR is named "PIRStudy", make its device type "Motion Sensor". Then add the scripts described below.
Should I understand to create a new "virtual" device (if so please instruct me on haw to) or Should I rename my actual device "OcchioMagicoFibaro-PIR" in "PIR-OcchioMagicoFibaro" (or something else)?
Claudio :)
simonrg
Post by simonrg »
You are going to rename your actual device, the idea is that then the script will know that this is a PIR just from its name and so will pick up any PIRs not just a single 1.
Further down the wiki page the idea is to add some parameters that allow you to set how long the PIR stays on for, whether it comes on only at night etc..
Of course the reason why I wrote the scripts was that I have some very simple PIRs which only say I've seen something and don't even turn off ever, it sounds like your PIR could do a lot of this itself, but it still may be nice to be able to set them from Domoticz rather than on the hardware.
cpighin
Post by cpighin »
simonrg wrote: You are going to rename your actual device, the idea is that then the script will know that this is a PIR just from its name and so will pick up any PIRs not just a single 1.
Thanks simonrg :) Since i would prefer to avoid the renaming of devices, is it possible to modify your script
-- ~/domoticz/scripts/lua/script_device_PIRs.lua
tc=next(devicechanged)
v=tostring(tc)
if (v:sub(1,3) == 'PIR') then
    c=v:sub(4)
    commandArray[c] = 'On'
    tmess = c..' On - time 0'
    print(tmess)
in order to consider only a device with a specific name (for example OcchioMagicoFibaro-PIR)?
Claudio :)
simonrg
Post by simonrg »
cpighin wrote:Thanks simonrg :) Since i would prefer to avoid the renaming of devices, is it possible to modify your script in order to consider only a device with a specific name (for example OcchioMagicoFibaro-PIR)?
You can modify it however you like - ;) .
Probably the easiest way to work with your device name is:
v=tostring(tc)
-- Look for a device name which ends in PIR
if (v:sub(-3,-1) == 'PIR') then
    -- Remove -PIR from the device name and then turn that device on
    c=v:sub(1, -5)
    print(tmess)
would just take the PIR off the end.
Alternatively just write yourself from scripts from scratch, a script_device_name.lua which turns on the light whenever the PIR is detected, then a script_time_name.lua which turns the light off when the last update was x minutes ago. How to do this is in the more flexible scripts.
cpighin
Post by cpighin »
simonrg wrote:
cpighin wrote: You are missing a closing bracket on your if line:
Simonrg, few days ago you corrected my LUA file that now works fine lighting On my lamp after a motion detection.
Now I would like to improve the system to ensure that the lamp comes On when the sensor detects motion and stays On unless no movements are detected for x time (120 sec. as an example).
You have just wrote
simonrg wrote:Alternatively just write yourself from scripts from scratch, a script_device_name.lua which turns on the light whenever the PIR is detected, then a script_time_name.lua which turns the light off when the last update was x minutes ago. How to do this is in the more flexible scripts.
and I understand that I can use the LUA file you corrected as the one that turns On the light and a new script_time_name.lua which turns the light Off when the last update was 120 minutes ago, eventually using parts of your article mentioned above.
Am I write?
Claudio :)
simonrg
Post by simonrg »
cpighin wrote:You corrected my LUA file that now works fine lighting On my lamp after a motion detection.
Am I right?
Claudio :)
Claudio, yes you can use your original script to turn the light on:
-- ~/domoticz/scripts/lua/script_device_occhio.lua
And then just a time script to turn it off after 120minutes.
Simon
