Should the tradfri switch and motion sensor work with zigate?
I have paired them, that worked. But nothing happens after that.
No motion response.
And for the button, not happens when pushing the button.
They are not in a group, just want them as a device in domoticz.
Zigate tradfri switch and motion sensor
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
Re: Zigate tradfri switch and motion sensor
May be some links to investigate:
* https://github.com/zigbeefordomoticz/wi ... -Remote.md
* https://github.com/zigbeefordomoticz/wi ... -Motion.md
* https://github.com/zigbeefordomoticz/wi ... Tradfri.md
The main issue is the Zigate which is filtering the group command.
So either your tradfri switch and/or motion sensor use the group 0x0000 and so you just have to enable Create Group 0x0000 (from the WebUI settings), or you have to pair the remote to create a group and then makes the zigate part of the group.
Instead other Coordinators which works well with the plugin are easier to play with those remote and scene controller
enable Create Group 0x0000 (from the WebUI settings) is working!
Thanks for your fast and good support. Keep up the good word.
