does anyone know if this controler is supported by zigbee2mqtt: Lonsonho Tuya Zigbee Smart Led Controller Rgb Rgbcw Voor Light Strip 5V-24V?
https://nl.aliexpress.com/item/1005001315938878.html
Thanks for contributing ideas
Compatibel Zigbee2MQTT?
- rolandtwilt
- Domoticz version: 2024.7
Re: Compatibel Zigbee2MQTT?
In the link you provided and in one of the reviews it says it does. Seems to be a TuYa clone so probably will work.
- rolandtwilt
zigbee2mqtt can't find it...?
- Domoticz version: 2020.2
It seems (externally) close to https://www.zigbee2mqtt.io/devices/TS0504A.html
Now, until you tried to join it to your ZB network, you wont get the answer (unless someone here already did the test).
Ultimately, it's always possible (and not too tricky, I did it few times) to add a new device to Z2M. But there's no guarantee that will work.
- rolandtwilt
Can you please tell me how to add a new divice to Z2M?
