IKEA Fyrtur, Tredansen and Praktlysing
- Domoticz version: 2023.1
Hi. I’m thinking about picking up some IKEA motorised roller blinds. Specifically the Fyrtur and the Praktlysing.
Has anyone gotten them to work reliably with ZiGate and Zigbee for Domoticz?
I need to be able to control the blinds both from Domoticz and with the included remote.
I’ve had a lot of trouble pairing the Trådfri outlet and remote with Domoticz. I still can’t seem to get both Domoticz and the remote working at the same time and have moved on to other alternatives.
The blinds are very interesting and I hope it can work out.
I’d appreciate any advice I can get before buying.
Domoticz 2023.2: Raspberry Pi 2B: Raspbian 11 Bullseye / Z-Wave JS 12.4.1 (docker): Aeotec Z-stick gen5 / Zigbee for Domoticz 7.1.007 [3.174]: PiZiGate 0321 / RFLink 1.48
- Domoticz version: 2024.7
Re: IKEA Fyrtur, Tredansen and Praktlysing - ZiGate
Seems to be supported by Zigate/ZfD plugin: https://zigbeefordomoticz.github.io/wik ... adfri.html
I personally have no issues pairing and using Ikea zigbee stuff with my Zigate. I have no IKEA blinds so cannot comment on that.
- Domoticz version: 2024.6
I had some IKEA bulbs that came with a remote that I could not pair with both zigbee2mqtt and the included remote.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
That should work with zigbee groups but I do not know how this works in Zigbee2mqtt, with Zigate/ZfD it works.
- Domoticz version: Stable
My IKEA bulbs work fine with zigbee2mqtt / Domoticz and the remote, put the bulbs in a group in z2m and then bind the remote to the group.
Thanks.
I am mostly interested in the blinds and how well they work.
So… I picked up a Fyrtur blind to test it for myself.
I can get it to pair with Domoticz but the percetage control won’t work. I can see the level change as the blinds are moving but I can’t set a percentage from Domoticz.
The IKEA Trådfri remote control setup is convoluted with a mandatory repeater involved and as a result I can’t get both Domoticz and the remote working in tandem.
I tried pairing all components with my ZiGate but couldn’t get a group going.
Still interested if anyone actually got this crap working.
Edit: I’m running Zigbee for Domoticz. It works great with most other, non Ikea Zigbee stuff.
If anyone got these blinds and remotes working reliably with Zigbee2mqtt I’d consider migrating to that.
- gizmocuz
@kris, I would just do a small/quick test with Zigbee2MQTT anyway. It works great and love the firmware update option. Works with the native MQTT Autodiscovery hardware in Domoticz
I recently installed a fyrtur blind and had some issues getting the state updated in domoticz (using zigbee2mqqt), but this is partially fixed (as explained in viewtopic.php?t=39084).
I had to reset all devices and include them in the right order (first the included repeater, then blinds and then the remote).
I confirm I can still use the remote directly by setting a bind in the remote settings as shown below. The destination has to be your fyrtur blind.
That’s great!
I’ll give Zigbee2MQTT a try then.
Can you also set a level (percentage) from Domoticz?
/Kris
/Kris
Yes, setting a level works and even the stop button when using blinds + stop.
If you are running Domoticz beta then the ZfD plugin perhaps need an update for changed Blinds behavior. Are you running stable6 or beta6?
Changing to zigbee2mqtt will be a much bigger change and I do not know what the level of support of Zigate for zigbee2mqtt is. Seems to be experimental.
I remember working on that issue with one guy. It was not straight forward as you need also to use the repeater.
Some stuff were possible and some other not.
I think the guy documented what was possible and what was not.
https://github.com/zigbeefordomoticz/wi ... ller-blind
Wiki is available here.
Zigbee for Domoticz FAQ
I followed the steps and I can pair all devices to Zigbee for Domoticz but I can't make the group.
I get "No devices found" when I try to add from the device list.
Updated to version 6.3.003 (stable) but no difference.
did you check that ?
https://zigbeefordomoticz.github.io/wik ... ller-blind
Yes, but the Device List is empty.
In Zigate Web UI Management->Group Management, press “Add New Group” and select blind(s) into group. Press “Validate” and group is created. Refresh Web UI page to see created group, and note “Group ID”
- Groups.png (112.49 KiB) Viewed 2146 times
Ain't that the truth...
Seems like I'm not enough of a linux/docker guy to figure this one out. I can't find a basic enough guide for me to even install Zigbee2MQTT correctly.
changed to the beta channel 6.4.006. No difference
With the latest beta I can get the remote buttons to register correctly in Domoticz.
From here, I should at least be able to script the desired behavior. But I still can't send a set level (percentage) for the blinds from Domoticz :/
Please do explain the the steps you are taking ?
