Recent updates seem to have broken my blinds setup.
Clicking on open or closed gives either
Error: Zigbee: Blind switch: unable to handle command "Open"
or Error: Zigbee: Blind switch: unable to handle command "Close".
Getting this in the log.
Oct 16 10:32:15 raspberrypi npm[537]: Zigbee2MQTT:debug 2022-10-16 10:32:15: Received MQTT message on 'zigbee2mqtt/0xb4e3f9fffe61e9a2/set' with data 'null'
Oct 16 10:32:15 raspberrypi npm[537]: Zigbee2MQTT:error 2022-10-16 10:32:15: Invalid message 'null', skipping...
i can still control them with the slider or a set to a % command. E.G i have two controlled as a group. turning on the group sends a set to 98% level which works to close them but the off to open them now does nothing.
Any ideas or workarounds that you know of would be welcome.
Thanks.
zigbee2mqttt blinds problem
- Domoticz version: 2025.1
Re: zigbee2mqttt blinds problem
As designed in Domoticz Beta (be carefull about his!!!)
New functionality is described here: viewtopic.php?t=39192
If you are using the Python plugin please check the repository for updates.
sundodger
Hi, I was reading the changes and did update everything to the latest (as of yesterday). Maybe it will take a while to catch up..
- gizmocuz
@sundodger, please create a issue on github
Please make use of MQTT Explorer, and include the config topic + payload of your blind
(<mqtt auto discovery topic>/xx/yy//config)
Here the same. After update to 2022.2 blinds not working anymore
Fixed the problem
Solution is to adapt next source-file of plugin:
zigbee2mqtt\devices\switch\blind_percentage_switch.py
Change 'cmd == 'ON' into 'cmd == 'CLOSE'
Change 'cmd == 'OFF' into 'cmd == 'OPEN'
- jjnh
- Domoticz version: 2023.1
Top Tip!! This indeed solved my problem with the zigbee blinds after upgrading Domoticz, zigbee2mqtt and the plugin.
My Pi crashed a few days ago and since there is almlst no Pi's available I went to an Odroid N2+
Thanks very much.
Thanks very much.
Odroid N2+ 4GB, Finally updated to 2025.2, with an RfxTrx433E, Zigbee2MQTT with Slaesh's CC2652RB, Zwave-JS-UI, SolarEdge, iRobot and P1 connected.
