Enigma 2 Set top Box Integration
pacitzu
Re: Enigma 2 Set top Box Integration
Post by pacitzu »
I have installed the xmltodict library with sudo apt install python-xmltodic
But I have the same problem.
2017-12-15 17:46:27.371 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2017-12-15 17:46:27.371 Build Hash: 494fff7, Date: 2017-07-30 12:19:41
2017-12-15 17:46:27.372 Startup Path: /home/pi/domoticz/
2017-12-15 17:46:27.591 Sunrise: 07:33:00 SunSet:16:30:00
2017-12-15 17:46:27.591 EventSystem: reset all events...
2017-12-15 17:46:27.921 PluginSystem: Started, Python version '3.5.3'.
2017-12-15 17:46:27.938 Active notification Subsystems: (0/12)
2017-12-15 17:46:27.951 WebServer(HTTP) started on address: :: with port 8080
2017-12-15 17:46:27.972 WebServer(SSL) started on address: :: with port 443
2017-12-15 17:46:27.975 Proxymanager started.
2017-12-15 17:46:27.977 Starting shared server on: :::6144
2017-12-15 17:46:27.977 TCPServer: shared server started...
2017-12-15 17:46:27.978 RxQueue: queue worker started...
2017-12-15 17:46:30.011 EventSystem: reset all events...
2017-12-15 17:46:30.012 EventSystem: reset all device statuses...
2017-12-15 17:46:30.119 PluginSystem: Entering work loop.
2017-12-15 17:46:30.213 RFLink: Using serial port: /dev/ttyUSB0
2017-12-15 17:46:30.244 Python EventSystem: Module not found - Trying to initialize.
2017-12-15 17:46:30.252 Python EventSystem: Initalizing event module.
2017-12-15 17:46:30.260 EventSystem: Started
2017-12-15 17:46:31.227 (MyRoomThermostat) Initialized version 0.3.6, author 'logread'
2017-12-15 17:46:31.922 Error: (Enigma2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Enigma2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2017-12-15 17:46:31.922 Error: (Zgemma) Module Import failed, exception: 'ImportError'
2017-12-15 17:46:31.923 Error: (Zgemma) Module Import failed: ' Name: xmltodict'
2017-12-15 17:47:30.071 Error: Zgemma hardware (8) thread seems to have ended unexpectedly
ProjektC
Domoticz version: 4.10717
Post by ProjektC »
mjray
Domoticz version: 2022.2
Post by mjray »
pacitzu wrote: Friday 15 December 2017 17:51 I have installed the xmltodict library with sudo apt install python-xmltodic
python-xmldict is the wrong package. Demoticz uses python3, so apt install python3-xmltodict
