I'm trying to use the timer function on a selector switch, but the value presented on the "Level" are all but the first (Level 0).
I use it as a season selector for the conditioning system , so I have "Summer" as level 0 and "Winter" on Level 10.
[SOLVED] Timer on selector switch
- cyberclwn
Re: Timer on selector switch
I think because it needs a Level (higher then 0) combined with the "on" command.
And the "off"-command means level 0.
Gr.
Gr.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
Hi cyberclwn,
thanks for your post.
You are right, using off as a command, it goes at level 0.
It's working for me, but it's a bit confusing.
- psubiaco
Re: [SOLVED] Timer on selector switch
This post is a bit old (Sep 2022, now), but still useful.
Setting timer for Selector switch device works well, now.
Please take care that to test it, you have to set at least 2 minute offset from now.
For example, if current time is 23:32 and you want to test now the Selector Switch set to a certain level, try setting OnTime 23:34 or later. If you set 23.33 (less than 1 minute from now) it will not work.
Paolo
Thanks for the info!
Users browsing this forum: FireWizard and 1 guest
