Switch an RGB bulb when motion between sunset and sunrise
ebretteville
Domoticz version: 2.3530
Post by ebretteville »
Hye,
I wanto Switch an RGB bulb when motion between sunset and sunrise.
I did "programmed" this blockly, but it doesn't work, any idea why?
jvdz
Domoticz version: 4.107
Re: Switch an RGB bulb when motion between sunset and sunrise
Post by jvdz »
ebretteville wrote: Sunday 18 September 2022 22:07 I did "programmed" this blockly, but it doesn't work, any idea why?
Yes, just think about your logic coded: Time will NEVER be >(Greater than) sunset AND ant the same time < ( smaller than) sunrice!
That needs to be an OR relation.
ebretteville
Thank you, but in my head to make between it should have been an and. Thanks for your answer. It solved my pbm. Also, I used motion according to the domoticz wiki but it was ON instead.
