I've installed a Homewizzard water meter. It's connected to Wifi. I need to import this data into domoticz on my pi.
I recently started to work with Domoticz. Not very experienced yet.
I'm also not a developper.
Does anyone have a simple python script or dzVents script to import the data in Domoticz?
The API is to get information from the water meter is simple. "LOCAL IP ADDRESS/api/v1/data" gives the following output:
{"wifi_ssid": blabla", "wifi_strength":100,"total_liter_m3":0.116,"active_liter_lpm":0}
Any help is appriciated.
Thanks,
homewizzard watermeter
willemd
- Domoticz version: 2024.1
Re: homewizzard watermeter
Have a look at the links in this thread : viewtopic.php?p=292408#p292408
You need to define HTTP poller hardware and create virtual devices and install a lua_parser script to import the values from the url onto the devices. I use it for kWh and P1 WIFI meters from Homewizard.
DLB001
Thanks for your reply. I'm going to try to set it up.
