I use domoticz in zigbee with Pizigate.
Do you know if Domoticz and Pizigate are compatible with ZLinky_TIC. I like ZLinky_TIC a lot but I don't want to make an unnecessary purchase if it's not compatible.
Regards,
Compatibility ZLinky_TIC with Domoticz and Zigate Topic is solved
Re: Compatibility ZLinky_TIC with Domoticz and Zigate
We are working on the integration despite the fact that the ZLinky is somehow buggy at that time, and there is no much firmware update coming up.
Then the level of integration will really depends on your subscription.
If you have a Base subscription in Histroique mode, then there is no issue, if now you are on a Tempo or other type of contract we might have to fine tune it with the plugin.
Here is where we are:
https://github.com/zigbeefordomoticz/wi ... gration.md
Be aware that it looks like a number of users on other forum are complaining about the difficulties to get it paired. It seems that it is link to interferences. So better that the ZLinky is not far from your network
In all case, I would be more than happy to support you, and we have a dedicated branch for now, where we focus on ZLinky developpement/integration
[EDIT] Last if you are using a Texas Instrument or deConz or SiliconLabs it would be much easier as we are surfering from ZIgate bugs
Wiki is available here.
Zigbee for Domoticz FAQ
Thank you pipiche.
It's a shame that Zlink is buggy.
My EDF subscription is very classique. A simple day/night contract .
I shouldn't have reception problems. The Pi is at 4 meters from the linky, in the same room.
Unfortunately, I use a Pizigate version 3.20. So there must be some bugs.
Best regards,
Best regards,
@soulearth, for your information we have one user for whom the Day/Nigh works and he is also using a ZiGate. So so far so good
If you read french
https://easydomoticz.com/forum/viewtopi ... 28&t=12561
If you read french
Great!!!
I will maybe try the experience. In addition I have the impression that you are very motivated and dynamic in the development and I really like this state of mind.
Information in French. The foot
Thank you pipiche
