hourly electricity prices in domoticz (Netherlands)
Amsterdam020
Domoticz version: 3.5629
Post by Amsterdam020 »
More and more electricity suppliers in the Netherlands work with hourly prices. For example Frank Energie (https://www.frankenergie.nl/goedkoop)
The take the same price as on the wholesale market: https://www.epexspot.com/en/market-data ... 2022-07-22
See also this article in the Dutch newspaper Trouw: https://www.trouw.nl/duurzaamheid-natuu ... ~be5aaae9/
Does someone has a script that scrapes this data and integrate the values in Domoticz (for the Dutch market)?
Rp3, youlesss, rfxcom, philips hue, dsb1820
renerene
Re: hourly electricity prices in domoticz (Netherlands)
Post by renerene »
following....
Alain
Domoticz version: 2022.1
Post by Alain »
I use Node-red to scrape the prices from a site and then inject them to user variables (24 of them). You need to define the user variables first (as float) so that you can fill in your own idx numbers for them. I split the flow into two pieces because the new rates are published at around 13.00 uur. I don't want todays rates being replaced by tomorrows in the afternoon.
[{"id":"c8e4410b.3d57","type":"function","z":"e6a51a23.5d9c38","name":"Uurtarieven tot 13.00 uur","func":"var msg1 ={};\nvar msg2 ={};\nvar msg3 ={};\nvar msg4 ={};\nvar msg5 ={};\nvar msg6 ={};\nvar msg7 ={};\nvar msg8 ={};\nvar msg9 ={};\nvar msg10 ={};\nvar msg11 ={};\nvar msg12 ={};\nvar msg13 ={};\nmsg1.payload = {\"command\":\"setuservariable\",\"idx\":20,\"value\":msg.payload.apx[24].prijsEuroPerMWh.toString()};\nmsg2.payload = {\"command\":\"setuservariable\",\"idx\":21,\"value\":msg.payload.apx[25].prijsEuroPerMWh.toString()};\nmsg3.payload = {\"command\":\"setuservariable\",\"idx\":22,\"value\":msg.payload.apx[26].prijsEuroPerMWh.toString()};\nmsg4.payload = {\"command\":\"setuservariable\",\"idx\":23,\"value\":msg.payload.apx[27].prijsEuroPerMWh.toString()};\nmsg5.payload = {\"command\":\"setuservariable\",\"idx\":24,\"value\":msg.payload.apx[28].prijsEuroPerMWh.toString()};\nmsg6.payload = {\"command\":\"setuservariable\",\"idx\":25,\"value\":msg.payload.apx[29].prijsEuroPerMWh.toString()};\nmsg7.payload = {\"command\":\"setuservariable\",\"idx\":26,\"value\":msg.payload.apx[30].prijsEuroPerMWh.toString()};\nmsg8.payload = {\"command\":\"setuservariable\",\"idx\":27,\"value\":msg.payload.apx[31].prijsEuroPerMWh.toString()};\nmsg9.payload = {\"command\":\"setuservariable\",\"idx\":28,\"value\":msg.payload.apx[32].prijsEuroPerMWh.toString()};\nmsg10.payload = {\"command\":\"setuservariable\",\"idx\":29,\"value\":msg.payload.apx[33].prijsEuroPerMWh.toString()};\nmsg11.payload = {\"command\":\"setuservariable\",\"idx\":30,\"value\":msg.payload.apx[34].prijsEuroPerMWh.toString()};\nmsg12.payload = {\"command\":\"setuservariable\",\"idx\":31,\"value\":msg.payload.apx[35].prijsEuroPerMWh.toString()};\nmsg13.payload = {\"command\":\"setuservariable\",\"idx\":32,\"value\":msg.payload.apx[36].prijsEuroPerMWh.toString()};\n\n\nreturn [[msg1,msg2,msg3,msg4,msg5,msg6,msg7,msg8,msg9,msg10,msg11,msg12,msg13]]","outputs":1,"noerr":0,"initialize":"","finalize":"","x":490,"y":620,"wires":[["568927a2.c89908","43d89f39.7c57"]]}]
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
willemd
Domoticz version: 2026.3
Post by willemd »
load the prices and more ....
viewtopic.php?p=294970#p294970
renerene
Post by renerene »
Here's a code to get Frank Energy prices:
--Frank Energie hourly energy prices
--forum: https://domoticz.com/forum/viewtopic.php?t=38880
--original script by willemD, see https://www.domoticz.com/forum/viewtopic.php?p=296716#p296716
--version 4/4/2023: added check to see if tomorrow's electricity values are already in, starting on line 93
--version 16/4/2023: make URL call daily instead of hourly, put the results in array, added function to calculate lowest price periods
local kwhPrice='kwhPrijs'                                       --device name for hourly kwh price | type: dummy device -> Managed Counter
local kWhAvg='kwhGemiddeld'                                     --device name for average daily price per Kwh | type: dummy device -> custom sensor
local gasPrice='gasPrijs'                                       --device name for hourly kwh price | type: dummy device -> Managed Counter
local ApiEUtoken='yourTokenHere'         --API token of user account from entsoe
local UrlStart='https://web-api.tp.entsoe.eu/api?'              --the kwh API website
local GASUrlStart='https://api.energyzero.nl/v1/energyprices?'  --the gas API website
local DocType='A44'                                             --day ahead prices document type
local PriceRegion='10YNL----------L'                            --region is set to The Netherlands (adapt to your need as per API documentation)
--Frank Energie settings, feb 2023:
local kwhTax = 0.21                                             --BTW/VAT; set to 0.21 (= 21%)
local kwhRaise= 2.05                                            --Frank Energie toeslag inkoopprijs+ (14.6 for all-in price, status 01-2023)
local gasTax=0.21                                               --BTW/VAT; set to 0.21 (= 21%)
local gasRaise=22 --ct
local header='dzDailyEnergyPrices'
		timer = {
		    --'at 15:37',  -- Timer to get new electricity prices. Adapt timer to your needs. Normally new electricty prices are available after 15:00.
		    --'every minute',
		    'every hour'
		httpResponses = {
			'EUDAYpricesToday', -- must match with the callback passed to the openURL command in the code below
			'EUDAYpricesTomorrow',
			'EZGASprices',
		devices = {
		    'triggerhulp', --dummy decive for debug purpose
	logging = {
		level = domoticz.LOG_INFO,                        --remove comment signs to display logs
		marker = 'dzDailyEnergyPrices',
	data = {
        kwh = {initial={}}, --kWh prices per hour
	execute = function(dz, item)
        function getKwhPrices (day)
	        --day is case sensitive and should be: 'Today' or 'Tomorrow'
	        if day == 'Today' then
	            offset=0
            elseif day== 'Tomorrow' then
                offset=24*60*60
                dz.log("wrong call, unknow day (case sensitive): " .. day, dz.LOG_INFO)
            local PricePeriodStart=dz.time.dateToDate(dz.time.rawDate,'yyyy-mm-dd', 'yyyymmdd0000', offset )
            local PricePeriodEnd=dz.time.dateToDate(dz.time.rawDate,'yyyy-mm-dd', 'yyyymmdd2300', offset )
	        -- compose the full URL
            local EUurl=UrlStart .. 'securityToken=' .. ApiEUtoken .. '&documentType=' .. DocType .. '&in_Domain=' .. PriceRegion .. '&out_Domain=' .. PriceRegion .. '&periodStart=' .. PricePeriodStart .. '&periodEnd=' .. PricePeriodEnd
	        	        dz.log("URL : " .. EUurl, dz.LOG_INFO)
	        -- launch the URL
			dz.openURL({
				url = EUurl,
				method = 'GET',
				callback = 'EUDAYprices'..day, -- must match httpResponses above
        function getGasPrices ()
        -- section to launch the EnergyZero gas prices API get request (UTC timing)
            -- always get current day data
            local GasPricePeriodStart=os.date("%Y-%m-%d",os.time()) .. "T00:00:00.000Z"  -- this first price is valid from 01:00 CET
            local GASPricePeriodEnd=os.date("%Y-%m-%d", os.time()) .. "T23:59:59.999Z"
            local usageType=2  -- GAS
            -- compose the full URL:
            local EZurl=GASUrlStart .. 'fromDate=' .. GasPricePeriodStart .. '&tillDate=' .. GASPricePeriodEnd .. '&interval=4&usageType=' .. usageType .. '&inclBtw=false'
            dz.log("URL : " .. EZurl, dz.LOG_INFO)
            -- launch the URL
            dz.openURL({
                url = EZurl,
                method = 'GET',
                callback = 'EZGASprices', -- must match httpResponses above
        function printPrices ()
            dz.log('Overview of kWh prices, per hour',dz.LOG_INFO)
            for hour = 0,47 do
                if kwh[hour] then dz.log('kWh ['..hour..'] = '..kwh[hour],dz.LOG_INFO) end
	   function shiftPrices ()
            dz.log('shift prices from 24..47 to 0..23',dz.LOG_INFO)
            for hour = 0,23 do
                if kwh[hour+24] then
                    kwh[hour]=kwh[hour+24]
                    kwh[hour+24]=nil
	   function updateAverage ()
	       average=0
            for hour = 0,23 do
                if kwh[hour] then
                    if average~=999 then average=average+kwh[hour]/24 end
                    average=999
            dz.devices(kWhAvg).updateCustomSensor(average)
            dz.log('Average kWh price is '..average..' ct (999 = error)',dz.LOG_INFO)
	    function cheapHour(duration)
            if duration < 1 or duration > 23 then
                dz.log('Invalid duration value: '..duration, dz.LOG_ERROR)
                return nil
            local kwhOrder = {}
            for hour = 0, 23 do
                local sum = 0
                local count = 0
                -- Compute the sum and count for the specified duration
                for i = hour, hour + duration - 1 do
                    if kwh[i] then
                        sum = sum + kwh[i]
                        count = count + 1
                -- Compute the average and order for the specified duration
                if count > 0 then
                    local avg = sum / count
                    kwhOrder[hour] = 1
                    for i = 0, 23 do
                        if kwh[i] then
                            local sum2 = 0
                            local count2 = 0
                            -- Compute the sum and count for the specified duration at i
                            for j = i, i + duration - 1 do
                                if kwh[j] then
                                    sum2 = sum2 + kwh[j]
                                    count2 = count2 + 1
                            if count2 > 0 and sum2 / count2 < avg then
                                kwhOrder[hour] = kwhOrder[hour] + 1
                    kwhOrder[hour] = 0
            local lowest = 1
            for hour = 1, 23 do
                if kwhOrder[hour] < kwhOrder[lowest] then
                    lowest = hour
            return lowest
        function getKwhOrderPosition(hour)
            if hour < 0 or hour > 23 then
                dz.log('Invalid hour value: '..hour, dz.LOG_ERROR)
                return nil
            local kwhOrder = {}
            for i = 0, 23 do
                if kwh[i] then
                    local order = 1
                    for j = 0, 23 do
                        if kwh[j] and kwh[j] < kwh[i] then
                            order = order + 1
                    kwhOrder[i] = order
                    kwhOrder[i] = 0
            return kwhOrder[hour]
	    --MAIN routine --
	    kwh=dz.data.kwh
	    if item.isHTTPResponse then
		    -- response to openURL (HTTP GET) request was received
		    dz.log(item.trigger..' <-- trigger',dz.LOG_INFO)
            if item.trigger=="EUDAYpricesTomorrow" or item.trigger=="EUDAYpricesToday" then
                if item.ok then
                    if item.isXML then   -- should be XML
                        --check to see if tomorrow's electricity values are already in
                        if item.xml.Acknowledgement_MarketDocument then dz.log("Acknowledgement_MarketDocument bestaat", dz.LOG_INFO) end
                        if item.xml.Publication_MarketDocument then dz.log("Publication_MarketDocument bestaat", dz.LOG_INFO) end
                        if
                        then
                            dz.log('Fout met XML - '..item.xml.Acknowledgement_MarketDocument.Reason.text,dz.LOG_INFO)
    		                --dz.log("Reason.code : " .. item.xml.Publication_MarketDocument.Reason.code, dz.LOG_INFO)
    		                for id = 1, 24 do
    		                    dz.log(item.trigger..' - debug [id='..id..']',dz.LOG_INFO)
    		                    if item.xml.Publication_MarketDocument.TimeSeries[1] then
                                    rawPrice=tonumber(item.xml.Publication_MarketDocument.TimeSeries[1].Period.Point[id]['price.amount']) --after 13:00 hr tommorow xml returns two timeSeries (not one), so check whether to use index number [1]
                                    rawPrice=tonumber(item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount'])
                                price=(rawPrice+kwhRaise) * (1+kwhTax) / 10
                                --local currentDateTime=os.date("%Y-%m-%d 00:00:00",os.time()+0*60*60+id*60*60)
                                if id-1<10 then hour='0'..id-1 else hour = ''..id-1 end
                                if item.trigger=="EUDAYpricesTomorrow" then
                                    currentDateTime=dz.time.dateToDate(dz.time.rawDate,'yyyy-mm-dd', 'yyyy-mm-dd', 24*60*60)..' '..hour..":00:00"
                                    -- examples from https://www.domoticz.com/wiki/DzVents:_next_generation_Lua_scripting:
                                    --domoticz.time.dateToDate('31/12/2021 23:31:05','dd/mm/yyyy hh:MM:ss', 'dddd dd mmmm hh:MM:ss', 1 )              -- > 'Friday 31 December 23:31:06'
                                    --domoticz.time.dateToDate('31/12/2021 23:31:05','dd/mm/yyyy hh:MM:ss', 'ddd dd mmm hh:MM:ss', -3600 * 24 - 3 ))  -- > 'Thu 30 Dec 23:31:02'
                                    dz.log('adding EL price [id='..(id+24-1)..']: ' .. price..' ['..rawPrice..' raw]' ,dz.LOG_INFO)
                                    kwh[id+24-1]=price
                                    currentDateTime=dz.time.dateToDate(dz.time.rawDate,'yyyy-mm-dd', 'yyyy-mm-dd', 0)..' '..hour..":00:00"
                                    dz.log('adding EL price [id='..(id-1)..']: ' .. price..' ['..rawPrice..' raw]' ,dz.LOG_INFO)
                                    kwh[id-1]=price
                                local historystring=price .. ";" .. price
                                --debug usage local historystring=7 .. ";" .. 7
                        	    dz.log("Used command for history update: dz.devices(kwhPrice).updateHistory(\"" .. currentDateTime .. "\",\"" .. historystring .. "\")", dz.LOG_INFO)
                                dz.devices(kwhPrice).updateHistory(currentDateTime,historystring)
                            --printPrices ()
                        dz.log('No XML received', dz.LOG_INFO)
                if item.trigger=="EUDAYpricesToday" then
                    updateAverage ()
                    getGasPrices ()
            elseif item.trigger=="EZGASprices" then
                if (item.ok) then
                    dz.log('gasprices ok', dz.LOG_INFO)
                    if (item.isJSON) then   -- should be JSON
                        --dz.log('start dumptable', dz.LOG_INFO)
                        --dz.utils.dumpTable(item.json)  -- dumpTable can be used for debugging
                        --dz.log('end dumptable', dz.LOG_INFO)
    			        --GasDayPrices.reset()  -- remove historic prices from previous run
                        dz.log('Average:'..item.json.average, dz.LOG_INFO)
    			        --waarde=item.json.Prices[1].price
                        changevalue=item.json.average * 100
                        if changevalue~=0 then
                            changevalue=(changevalue + gasRaise) * (1+gasTax)
                            dz.log('Gas price:'..changevalue, dz.LOG_INFO)
                            dz.devices(gasPrice).updateCounter(changevalue)
                            dz.log('ERROR: * NO GAS VALUE *', dz.LOG_INFO)
                            dz.helpers.notify(dz, header,'No gas value, daily price is not updated', -1,  2*3, 60*8,202302121111)
                        dz.log('No JSON received', domoticz.LOG_INFO)
                    dz.log('There was a problem handling the request. Item not ok', dz.LOG_INFO)
                    dz.log(item, dz.LOG_INFO)
                --continue with next set, kwhtoday -> gas -> kwhTomorrow
                getKwhPrices ('Tomorrow')
        else --item is timer or trigger
            printPrices ()
            --make sure to call these functions after the price array values are filled at 14:00 hr
            dz.log('the cheapest hour is: '..cheapHour(1), dz.LOG_INFO)
            dz.log('the cheapest five hours in a row start on:'.. cheapHour(5), dz.LOG_INFO)
            dz.log('current hour is on place '..getKwhOrderPosition(dz.time.hour).." where place 1 is the cheapest from today's 24 hrs")
            if
                dz.time.hour == 14 or --make a new URL call every afternoon, after the tomorrow prices are published on Entsoe (at 13:00 hr?)
                kwh[dz.time.hour]==nil --No price, after problem or reboot? --> Generate prices
            then --get new prices, make URL call
                getKwhPrices ('Today') --Tomorrow and gas are started automaticly, after today XML is handled. Order: today (kWh) -> gas -> tomorrow (kWh)
            elseif dz.time.hour == 0 then
                shiftPrices ()
                updateAverage ()
        dz.devices(kwhPrice).updateCounter(kwh[dz.time.hour]) --update device for hourly energy price
        dz.data.kwh=kwh
willemd
Post by willemd »
renerene wrote: Sunday 05 February 2023 11:23 I use it in a simple way to charge my car with openEVSE: if hourlyPrice < AveragePrice then EnableCharge
A more optimal way would be to rank the hours by price, lowest first, and then select the first hours in the list to charge your car, depending on number of hours needed, although that possibly would mean the charging will start and stop several times during the day.
Xenomes
Domoticz version: 2026.4
Post by Xenomes »
renerene wrote: Sunday 05 February 2023 11:23 Here is a dzVents script to get the daily Frank Energy prices.
Another usage is to determine optimal mix for house heating, gas versus electricity. When daily costs for both are equal, the most economic situation is reached. If gas costs are higher than electricity, the airco's should work harder.
Thanks for the script that i was looking for! Now waiting for 'Restful API access' to be approved!
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
renerene
Post by renerene »
Xenomes wrote: Friday 03 March 2023 19:51 Thanks for the script that i was looking for!
I have updated the script in that original post. Gas price calculation is improved.
After some weeks monitoring: kWh seems to be on spot on with Frank app. Gas price is a bit inaccurate
Xenomes
Post by Xenomes »
renerene wrote: Saturday 04 March 2023 23:08 I have updated the script in that original post. Gas price calculation is improved.
Thanks for updating, will update mine to.
Tinytuya
renerene
Post by renerene »
updated the script in the post above, to check if tomorrow's price are already available. In the previous version this would lead to an error in the log "attempt to index a nil value (field 'Period')"
However, still have to look into it, because
a) hourly kWh values seem to be not correctly updated in weekends, when daily XML is not published and hourly update therefor is not executed "if id==dz.time.hour then dz.devices(kwhPrice).updateCounter(changevalue)"
b) ther seems to be a time shift going on. XMLS values are from 22:00 hour to 22:00, and script fills from 0:00 to 23:00
renerene
Post by renerene »
I have updated the script once again, version 16 april 2023
New features:
2023-04-16 23:47:12.379 Status: dzVents: Info: dzDailyEnergyPrices: the cheapest hour is: 16
2023-04-16 23:47:12.384 Status: dzVents: Info: dzDailyEnergyPrices: the cheapest five hours in a row start on:14
2023-04-16 23:47:12.385 Status: dzVents: Info: dzDailyEnergyPrices: current hour is on place 21 where place 1 is the cheapest from today's 24 hrs
2023-04-16 23:47:12.363 Status: dzVents: Info: dzDailyEnergyPrices: ------ Start internal script: dzDailyEnergyPrices: Device: "triggerhulp (Dummy)", Index: 834
2023-04-16 23:47:12.368 Status: dzVents: Info: dzDailyEnergyPrices: Overview of kWh prices, per hour
2023-04-16 23:47:12.369 Status: dzVents: Info: dzDailyEnergyPrices: kWh [1] = 13.7456
2023-04-16 23:47:12.369 Status: dzVents: Info: dzDailyEnergyPrices: kWh [2] = 12.77034
2023-04-16 23:47:12.369 Status: dzVents: Info: dzDailyEnergyPrices: kWh [3] = 12.67233
2023-04-16 23:47:12.369 Status: dzVents: Info: dzDailyEnergyPrices: kWh [4] = 12.47994
2023-04-16 23:47:12.369 Status: dzVents: Info: dzDailyEnergyPrices: kWh [5] = 12.66628
2023-04-16 23:47:12.369 Status: dzVents: Info: dzDailyEnergyPrices: kWh [6] = 12.77155
2023-04-16 23:47:12.370 Status: dzVents: Info: dzDailyEnergyPrices: kWh [7] = 12.77155
2023-04-16 23:47:12.370 Status: dzVents: Info: dzDailyEnergyPrices: kWh [8] = 12.75582
2023-04-16 23:47:12.370 Status: dzVents: Info: dzDailyEnergyPrices: kWh [9] = 13.61008
2023-04-16 23:47:12.370 Status: dzVents: Info: dzDailyEnergyPrices: kWh [10] = 14.12433
2023-04-16 23:47:12.370 Status: dzVents: Info: dzDailyEnergyPrices: kWh [11] = 13.68389
2023-04-16 23:47:12.370 Status: dzVents: Info: dzDailyEnergyPrices: kWh [12] = 13.29548
2023-04-16 23:47:12.371 Status: dzVents: Info: dzDailyEnergyPrices: kWh [13] = 12.8381
2023-04-16 23:47:12.372 Status: dzVents: Info: dzDailyEnergyPrices: kWh [14] = 12.12541
2023-04-16 23:47:12.372 Status: dzVents: Info: dzDailyEnergyPrices: kWh [15] = 11.71159
2023-04-16 23:47:12.372 Status: dzVents: Info: dzDailyEnergyPrices: kWh [16] = 11.65472
2023-04-16 23:47:12.372 Status: dzVents: Info: dzDailyEnergyPrices: kWh [17] = 11.87131
2023-04-16 23:47:12.372 Status: dzVents: Info: dzDailyEnergyPrices: kWh [18] = 12.46905
2023-04-16 23:47:12.372 Status: dzVents: Info: dzDailyEnergyPrices: kWh [19] = 14.18846
2023-04-16 23:47:12.373 Status: dzVents: Info: dzDailyEnergyPrices: kWh [20] = 16.32653
2023-04-16 23:47:12.373 Status: dzVents: Info: dzDailyEnergyPrices: kWh [21] = 17.18805
2023-04-16 23:47:12.373 Status: dzVents: Info: dzDailyEnergyPrices: kWh [22] = 16.58305
2023-04-16 23:47:12.373 Status: dzVents: Info: dzDailyEnergyPrices: kWh [23] = 15.97442
2023-04-16 23:47:12.373 Status: dzVents: Info: dzDailyEnergyPrices: kWh [24] = 15.4154
2023-04-16 23:47:12.373 Status: dzVents: Info: dzDailyEnergyPrices: kWh [25] = 14.1328
2023-04-16 23:47:12.373 Status: dzVents: Info: dzDailyEnergyPrices: kWh [26] = 13.69599
2023-04-16 23:47:12.373 Status: dzVents: Info: dzDailyEnergyPrices: kWh [27] = 13.43221
2023-04-16 23:47:12.373 Status: dzVents: Info: dzDailyEnergyPrices: kWh [28] = 13.57015
2023-04-16 23:47:12.374 Status: dzVents: Info: dzDailyEnergyPrices: kWh [29] = 13.55805
2023-04-16 23:47:12.374 Status: dzVents: Info: dzDailyEnergyPrices: kWh [30] = 14.15216
2023-04-16 23:47:12.374 Status: dzVents: Info: dzDailyEnergyPrices: kWh [31] = 17.28243
2023-04-16 23:47:12.374 Status: dzVents: Info: dzDailyEnergyPrices: kWh [32] = 21.83203
2023-04-16 23:47:12.374 Status: dzVents: Info: dzDailyEnergyPrices: kWh [33] = 24.36214
2023-04-16 23:47:12.374 Status: dzVents: Info: dzDailyEnergyPrices: kWh [34] = 19.92507
2023-04-16 23:47:12.374 Status: dzVents: Info: dzDailyEnergyPrices: kWh [35] = 16.65686
2023-04-16 23:47:12.374 Status: dzVents: Info: dzDailyEnergyPrices: kWh [36] = 14.47765
2023-04-16 23:47:12.375 Status: dzVents: Info: dzDailyEnergyPrices: kWh [37] = 12.96878
2023-04-16 23:47:12.375 Status: dzVents: Info: dzDailyEnergyPrices: kWh [38] = 12.45937
2023-04-16 23:47:12.376 Status: dzVents: Info: dzDailyEnergyPrices: kWh [39] = 11.98384
2023-04-16 23:47:12.376 Status: dzVents: Info: dzDailyEnergyPrices: kWh [40] = 11.4708
2023-04-16 23:47:12.376 Status: dzVents: Info: dzDailyEnergyPrices: kWh [41] = 11.95601
2023-04-16 23:47:12.376 Status: dzVents: Info: dzDailyEnergyPrices: kWh [42] = 12.46784
2023-04-16 23:47:12.376 Status: dzVents: Info: dzDailyEnergyPrices: kWh [43] = 15.04998
2023-04-16 23:47:12.376 Status: dzVents: Info: dzDailyEnergyPrices: kWh [44] = 17.62486
2023-04-16 23:47:12.376 Status: dzVents: Info: dzDailyEnergyPrices: kWh [45] = 17.52443
2023-04-16 23:47:12.376 Status: dzVents: Info: dzDailyEnergyPrices: kWh [46] = 16.4923
2023-04-16 23:47:12.377 Status: dzVents: Info: dzDailyEnergyPrices: kWh [47] = 15.10927
2023-04-16 23:47:12.377 Status: dzVents: Info: dzDailyEnergyPrices: kWh [48] = 13.45641
renerene
Post by renerene »
tomorrow you can earn money, check position 15 in te code below. And debug your code, because negative values don't seem to work in the kwhPrice log statistics
<Publication_MarketDocument xmlns="urn:iec65325.351:tc57wg16:451-3:publicationdocument:7:0">
<revisionNumber>1</revisionNumber>
<type>A44</type>
<sender_MarketParticipant.mRID codingScheme="A01">10X1001A1001A450</sender_MarketParticipant.mRID>
<sender_MarketParticipant.marketRole.type>A32</sender_MarketParticipant.marketRole.type>
<receiver_MarketParticipant.mRID codingScheme="A01">10X1001A1001A450</receiver_MarketParticipant.mRID>
<receiver_MarketParticipant.marketRole.type>A33</receiver_MarketParticipant.marketRole.type>
<createdDateTime>2023-04-18T17:41:13Z</createdDateTime>
<period.timeInterval>
<start>2023-04-18T22:00Z</start>
<end>2023-04-19T22:00Z</end>
</period.timeInterval>
<TimeSeries>
<mRID>1</mRID>
<businessType>A62</businessType>
<in_Domain.mRID codingScheme="A01">10YNL----------L</in_Domain.mRID>
<out_Domain.mRID codingScheme="A01">10YNL----------L</out_Domain.mRID>
<currency_Unit.name>EUR</currency_Unit.name>
<price_Measure_Unit.name>MWH</price_Measure_Unit.name>
<curveType>A01</curveType>
<Period>
<timeInterval>
</timeInterval>
<resolution>PT60M</resolution>
<Point>
<position>1</position>
<price.amount>102.73</price.amount>
</Point>
<Point>
<position>2</position>
<price.amount>98.10</price.amount>
</Point>
<Point>
<position>3</position>
<price.amount>100.00</price.amount>
</Point>
<Point>
<position>4</position>
<price.amount>99.49</price.amount>
</Point>
<Point>
<position>5</position>
<price.amount>100.46</price.amount>
</Point>
<Point>
<position>6</position>
<price.amount>105.31</price.amount>
</Point>
<Point>
<position>7</position>
<price.amount>130.10</price.amount>
</Point>
<Point>
<position>8</position>
<price.amount>139.10</price.amount>
</Point>
<Point>
<position>9</position>
<price.amount>135.41</price.amount>
</Point>
<Point>
<position>10</position>
<price.amount>104.10</price.amount>
</Point>
<Point>
<position>11</position>
<price.amount>70.00</price.amount>
</Point>
<Point>
<position>12</position>
<price.amount>-3.40</price.amount>
</Point>
<Point>
<position>13</position>
<price.amount>-80.00</price.amount>
</Point>
<Point>
<position>14</position>
<price.amount>-200.00</price.amount>
</Point>
<Point>
<position>15</position>
</Point>
<Point>
<position>16</position>
<price.amount>-150.00</price.amount>
</Point>
<Point>
<position>17</position>
<price.amount>-30.00</price.amount>
</Point>
<Point>
<position>18</position>
<price.amount>66.37</price.amount>
</Point>
<Point>
<position>19</position>
<price.amount>90.28</price.amount>
</Point>
<Point>
<position>20</position>
<price.amount>119.90</price.amount>
</Point>
<Point>
<position>21</position>
<price.amount>128.36</price.amount>
</Point>
<Point>
<position>22</position>
<price.amount>122.98</price.amount>
</Point>
<Point>
<position>23</position>
<price.amount>109.90</price.amount>
</Point>
<Point>
<position>24</position>
<price.amount>101.66</price.amount>
</Point>
</Period>
</TimeSeries>
</Publication_MarketDocument>
