Hello All,
When I joined the Domoticz community, we already had in our possession two IP Cameras: D-Link DCS8000LH and SOMFY SomfyOne. These two are working via independent cloud server applications connected via clients apps on the iPhone and I would like to integrate them to Domoticz. The greatest peeve is to have to rely upon someone else’s infrastructure to monitor our home. Domoticz provides the freedom /responsibility to depend upon yourself to do to job.
The two cameras are in our LAN and they can be pinged. They work normally but with their respective apps.
I reviewed both WIKI and Forum for any reference about both equipment. Visited the site http://www.ispyconnect.com/sources.aspx. Although I tried various user/password combinations when adding a camera in setup, I was not able to connect to camera to Domoticz.
I found a link to a YouTube post where it seems that one must reset equipment until cloud base services are not automatically installed but there is a chance that camera becomes a “brick”/useless.
Before embarking on this quest, is there someone else who succeeded and how?
Your comments/help is most welcomed!
El Zorro
D-Link DCS8000LH IP Camera & Domoticz
- elzorrovega
- Domoticz version: 2025.2
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bookworm 64 bit OS 6.12.47+rpt-rpi-v8
Domoticz Version: 2025.2
zwave-js-ui: 10.4.2.d3a89a7
zwave-js: 15.3.1
home id: 3714679688
home hex: 0xdd698388
zwave-js: 15.3.1
home id: 3714679688
- FireWizard
Re: D-Link DCS8000LH IP Camera & Domoticz
Hi, @elzorrovega,
According to https://github.com/bmork/defogger it will never work, as local access seems to be missing, But perhaps this link is still useful for you.
- elzorrovega
Hello FireWizard,
Thanks for your prompt response.
I see that the link explains that the equipment’s firmware must be a certain version if one is to communicate with it.
When I have more time on my hands I will read this carefully and evaluate how risky it is compared to the default reset proposed by another internet post.
I will update my post with whatever results I manage to get.
Best regards
Best regards
zwave-js: 15.3.1
home id: 3714679688
zwave-js: 15.3.1
home id: 3714679688
