PIR:s Siemens byron sx script stopped working
jasifil
Domoticz version: 4.9700
Post by jasifil »
Hi!
My Domoticz running on a Rpi 3 model B crashed a week ago. I replaced the microSD-card and reinstalled Domoticz. I also updated the fw in Rpi and the Rfxtrx433E. Since then my Byron SX PIR motion sensors does not seem to send proper signal. In the log-file it says "Error: RFXtrx433E: Invalid data received!" This also means that the switches does not go on or off. I have tried to activate all protocols in the Rfxtrx433E with no luck. Anyone with an idea of what could have happened? I am using the scripts found here https://www.domoticz.com/wiki/Smart_Lua_Scripts and have done so for several years with no problems at all.
jasifil
Re: PIR:s Siemens byron sx script stopped working
Post by jasifil »
Problem solved! I just re-flashed the Rfxtrx433E device with Ext firmware instead of Pro1. It is also possible that I missed to set the device in Run Mode in the RFX flash tool after previous flash. I don´t remember if I did and I don´t know if it would work at all if I forgot. But now it works just fine. :)
