Oficial Docker Container Topic is solved
- heggink
- Domoticz version: 12451
Re: Oficial Docker Container
That's because the docker container does not run domoticz as a service but just starts the process.
if you want to check the process, you have to install procps (apt update && apr install -y procps) and then see if the process runs (ps ax|grep domoticz)
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
- heggink
if it helps, I run a simple dzvents script that prints a message in the domoticz log every minute:
That way, I can easily spot when things lock up or crash. I have most of my logging off since things are quite stable.
-- this script logs a message every minute
active = true,
on = { timer = { 'every minute' } },
execute = function(dz,item)
print('Domoticz alive')
}Docker in Truenas scale, close to latest beta
DASHTICZ 🙃
DASHTICZ 🙃
DAVIZINHO
thanks for the info!!heggink wrote: Thursday 04 August 2022 13:16 That's because the docker container does not run domoticz as a service but just starts the process.
and exist a method to restart the process, from a script inside the docker? or restart the docker?
I use a init.sh each time i update the docker image and after this execution i stop the container and start again. A comand at the end of the script that restar the docker or de domoticz process, will be perfect for me
- heggink
The 'normal' way is to restart the container...
A container is not a substitute for a virtual machine so you mormally restart the container instead of restarting processes within the container.
DASHTICZ 🙃
DASHTICZ 🙃
DAVIZINHO
And its posible to Restart the container with a comand inside the container?
Not outside, i need inside
- heggink
I am not an expert but, AFAICT, this is not possible.
You would need to build a workaround where, from whitin the container, you flag a restart (touch some filename of a file mapped into the container e.g. "restart_me" and then a cron type entry that checks for the file, deletes it and restarts the container).
DASHTICZ 🙃
DASHTICZ 🙃
DAVIZINHO
or maybe other workaround, but its a stupid idea... is make something that get a fatal error to the container and its reboot itself, because the autoreboot of the container is active.heggink wrote: Thursday 04 August 2022 16:27 I am not an expert but, AFAICT, this is not possible.
This is a bad idea, i know. hahaha, but maybe its will be easy
MacJL
- Target OS: OS X
Just kill the main process launched by the container. Depending its restart policy, it will restart just after that.DAVIZINHO wrote: Thursday 04 August 2022 14:49 And its posible to Restart the container with a comand inside the container?
Not outside, i need inside![]()
UPDATE : With docker, to set a restart poilcy that always restart the container when it exits, the command should be :
docker container update --restart always your_container_name-
DAVIZINHO
hahaha. it works.MacJL wrote: Thursday 04 August 2022 16:38Just kill the main process launched by the container. Depending its restart policy, it will restart just after that.DAVIZINHO wrote: Thursday 04 August 2022 14:49 And its posible to Restart the container with a comand inside the container?
UPDATE : With docker, to set a restart poilcy that always restart the container when it exits, the command should be :Code: Select all
in synology the autorestart is a checkbox, easy
i run a "pidof domoticz" and it returns 1
after this i run "kill 1" and the container stop, and then the container automatically on again
this is a bad solution, but perfect for my pourpose!!!!
Gianni
running domoticz Version: 2022.1 (build 14453) on docker with host ubuntu server 22.04
I have 2 questions.
I see that this image running python 3.7.3 but i cannot update the python version inside the container.
I installed deadsnake ppa and update to v 3.11 but that did not work.
2
I mnt my local folder to /opt/domoticz/userdata
This works perfect but when i install a plugin with pp manager it's instal the plugin to /opt/domoticz/plugins.
So i need to manually move the plugin every time i create one
How can i fix this problem?
First problem fixed
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
I just build my docker image self based on bullseye.
Looking out for ssl3 support so i can use bookworm with python3.10
I have 2 questions.
2
First problem fixed
jackslayter
- Domoticz version: stable
I will to move Domoticz installation to Docker-compose and Traefik install. Everything works except the IP log which is the internal Docker IP (172.x.x.x) instead of the external IP lan or IP public.
In traefik conf I add "forwardedHeaders" for "trustedIPs" and works fine with other containers (perhaps because they have an option "ip_header": "X-Real-IP" or "trustedReverseProxy=true"
Do you have a command to add this option or it does not exist yet (I use stable Domoticz version "2022.1") ?
Thank you
Thank you
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
ChrisH
I'm trying to get some smartplugs to work with Domoticz. The plugin requires PyP100 python module, which has PyCryptodome as a dependency. Unfortunately installing it with "pip install pycryptodome" results in the following error:
Is there anyway to get 'aarch64-linux-gnu-gcc' in the container? Or is there a workaround to get pycryptodome installed?
Why is this stupid forum software complaining about external url's in the code... just because there's a . between 2 characters...
error: command 'aarch64-linux-gnu-gcc' failed: No such file or directory: 'aarch64-linux-gnu-gcc'
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-_ery8obk/pycryptodome/setup. py';f=getattr(tokenize, 'open', open)(__file__);code=f. read().replace('\r\n', '\n');f. close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-u4h7_7cz/install-record. txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-_ery8obk/pycryptodome/Why is this stupid forum software complaining about external url's in the code... just because there's a . between 2 characters...
hugoleij
I want to mount Config/manufacturer_specific (dot) xml so i can edit the file. I try the following but the Config folder in the container and outside the container is empty.
Can someone help me?
volumes:
- ./config/userdata:/opt/domoticz/userdata
- ./config/Config:/opt/domoticz/Config
Gravityz
- Domoticz version: 2025.1
i do not think you can map 2 different subdirectories in the container to the same path(./config)
also it is better to define absolute paths so you see where things are mapped
please note you are mapping EXTERNAL directories to INTERNAL directories
so when you look in the internal directory you see the external data, not the other way around
in your case you are mapping external directory ./config/Config(which is empty) to the internal directory which was not empty but now is
Gravityz
to solve your problem
login the container
cp -r /opt/domoticz/Config /opt/domoticz/userdata (the internal directory Config is copied to external directory ./config/userdata
edit the config files externally with eg winscp
go into the container again and copy the modieid file back.
cp -u /opt/domoticz/userdata/Config/file /opt/domoticz/Config
login the container
mgugu
Docker simplifies life
Gravityz
as long as you stay inside the container.
whenever you want to do simple things like share files between containers or execute commands from one container into another container then life gets really complex.
MacJL
- Target OS: OS X
Hellohugoleij wrote: Wednesday 11 January 2023 11:49 Hi,
Can someone help me?Code: Select all
volumes: - ./config/userdata:/opt/domoticz/userdata - ./config/Config:/opt/domoticz/Config
Copy the file locally :
docker cp your_container_name:/opt/domotic/Config/xxx.xml .Code: Select all
edit xxx.xmlCode: Select all
volumes:
- ./xxx.xml:/opt/domoticz/Config/xxx.xml
aukesp
- Domoticz version: 2202.2
I try also to use Domoticz on a Docker container and migrate to zwave-JS on a Windows machine with Docker instelled.
Everything is going fine but....
My USB devices are not seen/ connected.
In all packages the note: Like the other methods replace /dev/serial/by-id/insert_stick_reference_here with the serial device for your Z-Wave stick.
Where ever I look i do not find any serial/ USB device.
Also the command: lsusb is not found??
ls -l /dev/ttyUSB0 gives no result.
Where am I going wrong or have I missed something?
It seems that docker on windows with USB access difficult to install, google on WSL Better to install Ubuntu on your system and use that.
Users browsing this forum: Menno and 1 guest
