Raspberry install. Deconz works fine standalone and is connected to some sensors. Can open Phoscon app and see the sensors.
Domoticz menu item Custom/Deconz opens and shows "loading".
I don't know how to get any further. I have looked at various links but I haven't grasped what else I need.
Is there a good run through guide anywhere that I missed? Thanks for any advice.
Conbee2 setup - Rasp
Thorgal789
- Target OS: -
Re: Conbee2 setup - Rasp
Hello, you have the procedure here for the deconz plugin https://github.com/Smanar/Domoticz-deCONZ
You need to install the plugin and get an API KEY using the tool provided, can be possible using the front end, but I m not sure.
For the front end (custom/deconz) stucked https://github.com/Smanar/Domoticz-deCONZ/issues/111
Need to use the "http" link, but you don't need it to use the plugin, just set your API key and the plugin will synchronise deconz with domoticz.
If it still not working, can you show your hardware panel config for the plugin ?
